LCD LED EDID EEPRom Dumps
    Re: LCD LED EDID EEPROM Dumps
    thanks smdflea already tried different screen still cannot detect.i have a question how to determine the type or manufacture of 24c02 chip on lcd screen?
      Ok, so i got a screen and programmed it with my old TL866 by jumping 2 test pads together with tweezers. The screen is a AO N156BGE-L11 .I jumped EE_GND and EE_WE (from pin 7 write enable/write protect) and it worked without having to desolder or solder wires from pi4 to 7.Check if your pcb has a similar silkscreen .
        thanks i already tried but still no luck maybe the chip is damage.but some of lcd already programmed i put only at2402 and some of them done programmed but others are error. is it possible to replace 2402 chip from other lcd
          Originally posted by String2016 View Post
          The lcd iS CHI MEI n156bge-l21 rev c1 and the chip with 8pin on the lcd board has only written 4327 6249
          The marking code could be a ST Micro M24C08 ,M24C32
            Yes if its not OTP .
              thanks smdflea, how do i know if it is OTP?
                and also is it possible to make a 30pin led connector?so that every 30pin screen can programmed too.
                  Watch this video, from 12min 30sec in https://www.youtube.com/watch?v=okWNwYbtzxA
                    thanks smdflea. i keep searching for this endid bin do you have this N156B3-L02 REV C1
                      No, i don`t have it. Heres the datasheet,on page 15 is the EDID layout:
                        @SMDFLEA I need a EDID eeprom file for this AU B140XW01 V.9 please!!I try to flash the corrupted screen
                          Can I get dump for BOE NV156FHM-A11
                            Here you go.
                              Sorry, i don`t have the dump or datasheet
                                @smdflea not working because your file has 128kb and the flash size for this is 256kb
                                  You can use a hex editor ?
                                    i dont know how to use it to make a file size larger, can you please make it 256kb file please
                                      Heres a 128kb FF file,copy and paste it onto the end of NP355V4C_B140XW01.bin
                                      https://mh-nexus.de/en/downloads.php?product=HxD20
                                        B140XW01 V9 256kb.bin
                                          Anyone have idea about macbook retina 15" EDID programming?
