Dell Latitude 3400 bios password -E7A8
    Hello folks,
    I am trying to find the bios password of my Dell Latitude 3400, but no success so far. I have tried https://bios-pw.org/ but the provided password do not work.
    The service tag is 22VXQ23-E7A8. Can anyone help me?
    Thanks!
    Re: Dell Latitude 3400 bios password -E7A8
    I can't find a free way to remove the BIOS password on your laptop.
    Your laptop is showing warranty with Dell until 2023, so contact them and they should be able to help you.
    They can probably send you a code or something to remove the password once you provide proof of purchase.
      Thank you BL4K3Y, but Dell support was unable to help me. After two weeks of waiting for an answer from them they sent me a code that did not work.
        post your backup bios here
          got one with password. please check attached backup
          thanks..
            thanks..
            try..
              Originally posted by peste View Post
              try..
              tried your file but the unit won't turn on...
                anyone could share a good bios file?
                  Hello.
                  Can anyone help to remove password from Latitude 3400 ?
                  Original dump attached below.
                  Thx!
                    it's not proper bios
                      send old dump
                        thanks..
                        Try & Update Me....
                          Originally posted by tracker1 View Post
                          Hello.
                          Thx!
                          put proper backup bios
                            put your old bios backup
                              otherwise try this also
                                sorry i can't try it anymore on actual unit. the unit was already pulled out by the owner. but i tried it on the other unit with HDD detection problem, it ended on a dead unit.
                                board infos:
                                BOLT-L UMA_17938-1_FW8G6$LA - with bios password (pulled out)
                                BOLT-L UMA_17938-1_FW8G6$CA - with HDD detection problem
                                  Try & Update Me....
                                  tried on other unit but the password still present...
                                    Don`t expect a reply, he`s banned.
                                    I think the password on this model is in the EC ,not sure.
                                      Good night! Could someone help me with the "master password" Do the DELL Latitude 3400 Service TAG 5RHDK03-E7A8?
                                        @Silvano Tark
                                        Service Tag : 5RHDK03-E7A8
                                        Password#1: 62Ij3dzx6ND[8qkI
                                        6 - six ( number )
                                        2 - two ( number )
                                        I - INDIA ( UPPERCASE )
                                        j - juliett ( lowercase )
                                        3 - three ( number )
                                        d - delta ( lowercase )
                                        z - zulu ( lowercase )
                                        x - x-ray ( lowercase )
                                        6 - six ( number )
                                        N - NOVEMBER ( UPPERCASE )
                                        D - DELTA ( UPPERCASE )
                                        [ - opening bracket ( character )
                                        8 - eight ( number )
                                        q - quebec ( lowercase )
                                        k - kilo ( lowercase )
                                        Password#2: JM8XIzayJx8ypJ6c
                                        J - JULIETT ( UPPERCASE )
                                        M - MIKE ( UPPERCASE )
                                        X - X-RAY ( UPPERCASE )
                                        a - alpha ( lowercase )
                                        y - yankee ( lowercase )
                                        p - papa ( lowercase )
                                        6 - six ( number )
                                        c - charlie ( lowercase )
                                        Type password then hold down the left CTRL key and press <Enter>
                                        Nb: If the first password #1 doesn't work use the second password.
