840 G2 Machine Is Not In Committed State
    i have 840 G2 without bios chip and dump file
    I put on a new chip, I put some bios file, which I had
    the laptop turns on, a little slower, but it writes Machine Is Not In Committed State
    this is my bios file
    Re: 840 G2 Machine Is Not In Committed State
    you probably flash a new virgin bios thats why this massage appears on screen on boot up
    search for DMI TOLLS in BADCAPS and fill the information
    or search in youtube there is tons of vidos available on DMI TOOLS
      what model of motherboard does the laptop have ??
        This is picture
        is this enough?
          This is pic
          the model is written on the white paint plate.
            6050a2637901-mb-a02
              6050a2637901-mb-a02
              if it works you have to enter the DMI information ... you have here ...
              https://www.youtube.com/watch?v=9T57ktw8n3Y
                No it wasn`t a virgin bios.The error was corrupt ME firmware.It has 1.5MB consumer FW as well. All the other dumps here have corporate FW,whether or not AMT is commited or not, so i assume someone has tried to clean the ME FW with "Easy Clean" or something and used the wrong FW .
                  SMDFlea
                  I don't have virgin bios file ,i don't have nothing...
                  I have laptop without bios chip, and i use NEW bios chip,program some 840 G2 dump file from forum, and solder
                  I try
                  And laptop is power on,show picture,work fine,but it writes Machine Is Not In Committed State
                    SMDFlea
                    I try
                    I know that,i have read the whole thread.I`m pointing out that the dump you tried has corrupt ME firmware,hence the error message you have.
                    EDIT: You`ve asked for an 840 G2 bios before - https://www.badcaps.net/forum/showthread.php?t=90182 ,you could have used that bios with clean ME firmware
                      SMDFlea
                      My post where i ask for 840 G2 CLEAN ME, is my mistake in TITLE, it is 840 G1
                      yes, i need 840 G2 with CLEAN ME
                        SMDFlea
                        have you tried post # 7 ??? ...
                          SMDFlea
                          Yes i just checked,the bios had bid L71 .Rather than correct the title and edit the posts it was easier to delete the whole thread, just so members don`t download it anymore, thinking its an 840 G2 bios.... ,if you can post a link to the corrupt bios you tried i`ll delete that post/thread as well.
                          Try the bios posted by @peste at post # 7
                            peste
                            my friend ,your M71_0113+outimage.rar WORKS FINE
                            Now i must enter the DMI information , just like you said
                            I never did that, but i try with yot youtube link
                            thank you many times
                            SMDFlea thank you for your help...you are also right about everything
                            now i will try to insert the DMI info, so i will let you know what i did
                            thanks friends
                              peste
                              I finished ssuccessfully insert the DMI info in bios file
                              now everything is perfect
                              I learned a lot thanks to you and SMDFlea
                                tell us how you did it to insert in the DMI info
                                  You have to use HP's DMI tool. These are not available for download via HP official site but there is a collection of all the leaked ones in a separate thread.
                                  https://www.badcaps.net/forum/showth...ghlight=dmifit
                                  You have to create a FreeDOS bootable USB and use the DMI tool suited for your laptop and enter the DMI data. There is a demo Youtube video link in post #7. It's not in English but will give you an idea about the process.
                                    NEED HELP BIOS HP840 G2 "Machine not in commited state"
                                    After a Bios update appeared "Machine not in committed state". I tried the Bios setup procedures with HP tools, but even after using them, the pc still shows this message and takes a long time to boot. Sometimes it crashes during startup. I wonder if the BIOS file is not corrupted? Thank you in advance for your help.
                                    Here is the pc info:
                                    Product Name: HP EliteBook 840 G2
                                    SKU Number: G8S00AV
                                    Serial Number: 5CG5440KFZ
                                    UUID: 7F1D5FC22216E411A13F62B5AC02C0FF
                                    Asset Tracking Number: 5CG5440KFZ
                                    SYstem Configuration ID: A3009D510303
                                    Warranty : 3y3y0y
                                    Enter Feature Byte: 3X47676J6S6b757H7M7Q7WaBaqawce.Y3.
                                    Enter Build ID: 13WWCODW601#SABD#DABD
                                    System Board ID: 2216
                                    System Board CT: PEVMP00WB9M6Q1
                                    Current System Bios Version: M71 Ver. 01.31
                                    Current BIOS Release Date: 02/24/2020
                                    Video BIOS Revision: INTEL(R) Core(TM) i5-5300U CPU
                                    MicroCode Revision: 2F
                                    MAC Adress: 88-88-88-88-87-88
                                    MAC: DC4A3E07C4D8
                                    And here is the extracted BIOS file:
                                      Re: NEED HELP BIOS HP840 G2 "Machine not in commited state"
                                      Post original bios file.
                                      Become a Badcaps supporter
                                      Thanks to all supporters.
                                        Hello, this is the file I extracted from the bios. I don't have another because I didn't update it. What can I do?
                                        Thank you
