RCA LED46C45RQ,Sound but no Back lights
    Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
    Has All voltages coming from main board.No voltage going to
    Back lights from power board.Have no Schematic.Back lights work when
    Led Back light Strip tester is used.Tester shows 110 volts from each
    side.Also if you use the side controls and use the vol +or- tv shuts
    down.
    Thanks for any help
    Re: Sound but no Back lights
    You have 0v at led connector when you power on?
      Your LED tester may not detect the bad LEDs since it runs at much lower current than the TV.
      Every RCA LED TV I've encountered had bad backlights if it turned on with no backlight or flash of backlights. Impossible to get new LED strips for them so I repair the individual LEDs and turn down the backlight level as low as possible in the service menu. Menu-1-1-4-7 or source-2-5-8-0 under panel settings. I've encountered models where lowering the backlight didn't save or I couldn't adjust it with the remote cursor buttons. Some do have energy savings picture mode which run the backlight a little lower than max.
        Yes 0 volts
          When tester is put on back lights ,It lights in full Brightness-no dark spots. Picture Perfect
            So power board is bad. Need to check components in led circuit.
              I can't find a LED46C45RQ Schematic (RCA)
                Re: RCA LED46C45RQ,Sound but no Back lights
                Need good pictures of boards.
                  Hope this helps
                    And you are getting your BL_ON voltage? Need to check ds2 and ds2a for shorts. Also need one good picture of whole back of board.
                    https://www.shopjimmy.com/rca-re46hq...ply-led-board/
                      Took ds 2 and ds 2a out of circuit , checked good also Qs7&9
                        down.
                        Thanks for any help
                        So you have the BL_ON voltage for sure?
                          FYI Just got new board installed it and the same thing happening
                            Which board? Power supply? Main?
                              Power supply
                                I suspect you are not getting the BL-ON voltage from the main board to turn on the back light circuit
                                  Also I noticed that when tv starts up I get voltage at connector going to back light and then the voltage drops off (new board)
                                    What does the BL-ON voltage do on CON4 when the tv is first turned on? does it stay the same level when the backlights are on and then turn off?
                                    You likely have a bad led in the panel. one bad led will trigger the backlight protection circuit to shut down.
                                      got 5 v sb rest dead turn on tv got all voltage that are supposed to be there 12v 5v etc.
                                        Will tear it apart and see.
