I have a Sony 55x8000f that has three vertical lines (three different colors), with the lines still showing when the cable from t-con board to the panel is disconnected. Am wondering what might be causing this? Unfixable panel problem?
Three vertical lines without t-con board connected: Sony 55X8000F
Re: Three vertical lines without t-con board connected: Sony 55X8000F
Thx. So either a tab bond or driver IC issue i assume. Or can the issue be inside the actual polarisers? Since it seems to be a couple of lines, I'm inclined to believe it's a driver IC issue?Last edited by iampivot; 04-19-2022, 07:56 AM.
