Openflex Boardview: New boardview software (linux, windows and OSX)
    Re: Openflex Boardview: New boardview software (linux, windows and OSX)
    ASC is not supported at the moment?
      Is that the format with multiple files (ie, pins.asc, outline.asc etc ) ?
      YouTube Repair Videos - https://www.youtube.com/user/19PLD73
      FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
        yes, that's the one.
          Thanks. There's a fellow piernov who will probably be working on that over the next couple of days. The separate file format and one of the existing brd formats are quite similar, just the one we've already done everything is consolidated in to a single file (rather than split in to separate ones).
          You can keep track with development if you like at this URL -
          https://github.com/inflex/OpenBoardView/issues/43
            Basic support implemented, see https://github.com/inflex/OpenBoardV...ment-244615864 .
            You can grab the binaries here: https://github.com/piernov/OpenBoard...leases/tag/N10 .
              well unfortunetly your software gives a lot of runtime error , specially it didn't open yet any .FZ file !!!
                Can you give us a dump/error? What Windows OS?
                Also, do you have the FZ key installed so you can decode the fz files?
                Perhaps come over to the Github repo and make an issue-ticket?
                  hey back .
                  let me chek hold on
                  so OS is windos 10
                  what do you mean about FZ key installed ( i usually open them on "PCB Repair Tool" and no issues and nothing needed .
                  sorry im not software expert here , my thing is the electronics :P so feel free to tell me what do i need
                  cheers
                  here are some fotos of the runtime errors
                    Yep, they're all relating to the lack of the FZ Key sadly.
                    Because it's Open source software, we cannot legally supply it with the required FZ decoding key (it's available, many people have it, but we cannot provide it).
                    One of those annoying issues
                    I might talk with piernov and see what we can do about making those "Assert" errors a little more human readable, thanks.
                      thk , so were do i can find does fz keys , and were i need to put them ?
                      cheers
                        well managed to get does fz. files , it works like a charm now
                        thk for the help
                          thk for the help
                          can you share your key ? cause i have the same problem !
                            You can come and and ask on our IRC channel: #openboardview@irc.freenode.net
                              i don't use irc, it's too much if you share it by mail or pm ?
                                Did you get the key eventually?
                                  Release (R6) went up last night. Available directly from the website; http://openboardview.org
                                    thank you inflex
                                      thank you inflex
                                      In this case, it was piernov's work that got the multifile-asc format to work
                                        Yes Buddy, using it right Now !
                                        thank you for both of you
                                          If anyone reading this is also having troubles with their key disappearing, edit the obv.conf file, remove all dud/duplicate lines starting with FZKey = , so that you have only a single one left with the right key in it.
                                          After that single entry, place at the bottom of a file, some random comment line, such as;
                                          # end of configuration
                                          FZKey = 0x25d8d248 0xe1502405 0x56b5d486 ... 0x0681955f ( and a lot more after that )
                                          # end of configuration file
