td system k32dlm7h firmware tv
    Hello.
    I have a problem with this tv. It constantly restarts just showing the logo. It has panel lc320dxy-ska8 and board cv512h-u42. I have seen firmware for the lc320dxy-ska6 panel on other forums but I have not been able to download it. I think how well it could be valid but I'm not sure. If someone can pass me some firmware I would be very grateful. Thank you
    Re: td system k32dlm7h firmware tv
    Galatec tvs-3205mc _cv512h-u42_lc320dxy (sk)(a8)
      My eeprom is 25q64jvsIQ winbond. It is not listed in my programmer. Could I select another type of model to read write?
        What programmer?
        W25Q64 can you just put it out?
          Originally posted by lotas View Post
          What programmer?
          I use sofi sp8-A.
          In auto detect there are several options. I have selected 25q64cv. It reads correctly, but since it is not exactly the same id I am afraid of corrupting the dump and losing it.
            And there is no superfluous one, some kind of 64 spi flash, so as not to touch the original one.
              Sorry friend but I did not understand your last comment.
              I installed the dump you gave me and the symptoms were the same. It would start up and shut down, then sometimes it doesn't respond to the buttons but other times it does. I think it's a cpu failure or some other component. I have moved tv a bit and now it works perfectly so I would think that maybe it is a problem of negative to the main ones.
              Any suggestion would be welcome.
                check all the solder joints if you haven't already.
                  It fails randomly, it is not due to the movement of the tv. I think there may be a cold weld. Tomorrow I am going to apply hot air to the processor and other components with the hope that the fault will subside.
                    By the way. Thank you very much for the help
                      I meant to write a dump to another (new or removed from some kind of donor) not exactly like your original, but from a different company.
