LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by Alassane View Post
    you can help me please
    You have two bios chips, 4MB and 8MB, upload both.
    Become a Badcaps supporter
    Thanks to all supporters.
      Originally posted by hoaca388 View Post
      you have two bios chips, 4mb and 8mb, upload both.
      here are the two chips bin
        Have you tried using the autopatcher at post #1 ?
          @SMDFlea , I tried concatenating 2 bios files and running autopatch but it didn't work.
            Can someone help me patch my T495
              yes i tried but it didn't work
                patch only the 4mb and follow the instructions carefully. There might be a tamper switch you have to press in thats usually pressed in by the base cover.
                  Originally posted by tech_1612 View Post
                  Please help patch attached dump. I am having issues running python under cmd. Thanks
                  cleared
                    pleace help lenovo t550 bios locked
                        I'll check now
                          work thenk you
                            Members should be encouraged to try it for themselves when the tools are available
                              I tried it always gives error on 4 MB and 8 MB you can try for me ?
                                Hi folks. I've read the post and how to do the autopatcher steps. New to this so learning rather quickly.
                                I ran into a roadblock however. I managed to get a good bios.bin from the T570 and patched it. Python 3 is used and everything reports completed. When I flash the patched .bin it continuously comes up with errors when verifying/writing. Usually at the same spot. While the test clip I have is crappy, I did manage to flash back the original BIOS with ASprogrammer just fine so I know the clip is attached fine. Flash to the patched bios and errors again.
                                Not sure what I'm missing, but will figure it out. In the meantime could someone help me out by patching my bios attached. I want to make sure it's not just me, and if it is I will try and figure out what I'm doing wrong.
                                Thanks in advanced.
                                  These bios is patched works 100% you can try
                                    I have not succeeded in patching x1 carbon until now can you help me?
                                      If mobo code "Wistron Genesis-1 LGS-1 11246-1" then password is inside small eeprom U42
                                      http://www.ja.axxs.net/x1_carbon.htm
                                        Thanks in advanced.
                                        Here :
                                          Hi.
                                          I tried patched my bios Lenovo T550 but I don't have lucky.
                                          Can someone help me please?
