Dell E5440 completely dead
    Re: Dell E5440 completely dead
    I'll try it and then i'll try bios dump, report in a while
      Spider can you please give me your opinion on this ->https://www.badcaps.net/forum/showth...t=98968&page=2
      After a shortcircuit i have 20Ω short to the GND, same situation probably.
      From post #31 and so on.
      Thank you in advance.
        Needed bios dump too, now power on but return LED error code "A possible processor failure has occurred."
        Perhaps a voltage is missing from what i solder OR cpu is indeed fried?
          Try with a known good BIOS first. The check the voltage on all the coils with laptop ON. Post your results for each coil.
            Just noticed this laptop has a EC chip too. Can you confirm it is U86 to flash it too?
              U86 is an AND gate. KBC/SIO is U38 (MEC5075), it is programmable but I don't think its an issue. You'd need SVOD programmer for that. Chip also has 2 rows of pin, 1 visible on the side and another under the chip.
              Try a known good BIOS and post your voltage measurements.
                I'm waiting for bios with confirmed vPro support, posted request in E5440 bios thread.
                After that i'll flash it and try again.
                  Fixed.
                  I replaced U1, i flashed the bios SMDFlea suggested and worked.
                  Never before seen a "A possible processor failure has occurred." LED error blink due to bad bios and/or bios chip.
                  Well i assume i learn as i live.
                  Thank you both!
                  Back to 7510 problem now that hunts me in my sleep.
