Problem on powered speaker installation
    Hello everyone
    I have a problem with an installation that I made, I installed 4 amplified speakers in a new room that is about to open, when the coffee machine is activated, on one of these speakers in particular you hear a noise, like an electric discharge, when it is pressed and released the coffee dispensing button, but the same noise is heard if you connect a drill for example.The signal cable that starts from the mixer passes inside the wall and a shielded and balanced three-pole cable, thinking it was the one I tried with an external one but nothing changes, I think it's a current, If you find it useful, the speakers are Proel flash5av2. Can someone help me? Thank you
    Re: Problem on powered speaker installation
    Try not having any inputs connected (remove input the cables) to the amplifiers and then see if you still get the interference from those noisy devices, if you do then the amplifiers are picking up the noise that is injected into the AC line, if that is the case you may have to put line filter at the source of the noise, or you can try AC line filter at the amplifier instead.
      do you mean EMI noise filter?
        Yes.
        For example: https://www.onfilter.com/ac-power-line-emi-filters
          what characteristics should this filter have? what you posted to me is not available in Italy, I have seen some around on the internet but I am afraid of making a wrong purchase, I have also seen some power strips with built-in filter
            Today I tried to unplug the signal cable and the noise is not heard, but I also tried to connect a vacuum cleaner instead of the coffee machine and with that it does not make noise
              Oh, so you did not do this as suggested before looking into the EMI filter?
              1) So what what are the audio sources that feed the amplifiers? Just one audio sources? If you have more then one sources connected then you have to try just one source at a time.
              2) Are the audio sources Balanced Outputs?
              3) What happen if you have the Balanced audio cable connected to the amplifiers on one end and another end of the cable pins are grounded, do you still hear the noise?
                all ends are balanced, there is a mixer to which the speakers are connected, to the mixer as a source there is a tablet, I partially solved the problem, two of the speakers were connected to an unbalanced mixer output, basically two some speakers were connected on the main mix of the mixer which is balanced and the other two I had connected on the control room to separate the volumes but the control room output was unbalanced and created the problem for me, the mixer has 4 balanced outputs two xlr and two jack, now I have connected everything on the balanced outputs but a speaker connected to an xlr continues to give me the problem, next to the offending speaker for example that a bathroom that has a neon as a lighting source, when this neon lights up, you hear the noise
