TV has the 8 LED error code. This normally means the SS board is bad. If I follow the service manual and disconnect ss11 it still has the 8 error code but if I remove the cable to c23 from the ss board the tv has no error code and the tv stays on. Does this mean that the C2 board is bad or could it be the panel. I did check for continuity between pins 1 and 2 of ss61 and ss66 and they were fine.
panasonic TC-P65ST30 8 power led error code
