UN55fh6200 Rebooting when warm
    I was given this tv. When it's cold it works fine. When it warms up it shuts down for a second then starts up again. I changed the caps but it's still doing the same thing. I turned the brightness level down and it seems to be fine so would have a have a faulty led strip?
    Re: UN55fh6200 Rebooting when warm
    So how low of the backlights (not Brightness) level you turn it down to?
    Pictures of the back side of the TV showing all the boards so we can see what we are dealing with?
      I'll get some pics tomorrow. The highest level is 20 and I have it set to 5. I haven't incremented it to see how high it will go before it starts rebooting again. I got sidetracked. I plan to dig deeper into it tomorrow night.
        I would also remove the LED connectors, power supply to main board connectors and inspect them to see if any one of them has the sign of over heating, also try tapping on the boards, check board mounting screws, etc.
          Usually an LED fault will just shut the TV down and not re-power over and over. You probably have a thermal issue somewhere. Since turning down the LEDs seems to help the issue, I would look at the LED driver portion of the PS.
