I have a LED 80 watt yard light with a sold state circuit board bad capacitors
    This light got to where it would turn on when it felt like it ( photo cell controller board issue )
    It has one 47uf@50 volts and one 10uf@50 volts double rating on the ESR reading ( non brand name capacitors )
    Now every time I cover the photo cell and remove cover it turns on and turns off like it should
    I will try to take a picture of the little board before I put it back together
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: I have a LED 80 watt yard light with a sold state circuit board bad capacitors
    I used to run through bags of these photo cells. These days I am way too busy to bother with them.
      At first I thought it might have been the photo cell but when I saw this circuit and how it was setup I just replaced the capacitors first and see what happened next when it now respond to light and darkness I knew that what the problem was
      9 PC LCD Monitor
      1 Dell Mother Board
        Update it has been running for last 2 days and nights with out any problems
        9 PC LCD Monitor
        1 Dell Mother Board
          I have torcher tested yard light for a week now and it has been running flawlessly so this has been a successful repair
          I been using it with the photo in the dark then every once in awhile I shine a light on the photocell and shuts right off then remove the light from the photocell and turn right back on
          9 PC LCD Monitor
          1 Dell Mother Board
