Has anyone used this product before / is this real or BS claims
    https://dailytrendingtech.com/produc...RoCHE0QAvD_BwE
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Has anyone used this product before / is this real or BS claims
    1) Any website that continually spams me with "xyz just bought 4, order now" already has me suspicious.
    2) Yes, ISPs likely give you the cheapest possible router. However, I don't believe for 1 second that "a cheap router that gets slower over time."
    3) Poor grammar also raises red flags. For example, "Thanks to brilliant engineer"
    4) Stay away is my advice.
    If you have problems with wifi in your enviroment, starting by troubleshooting, doing a wifi site survey, etc, etc.
    --- begin sig file ---
    --- end sig file ---
      Ok
      I thought it was BS
      Thanks for confirming this for me
      It was an advertisement on a music videos on YouTube not something that I got emails about
      9 PC LCD Monitor
      1 Dell Mother Board
        If you are watching youtube on your desktop computer, I suggest ublock origin. It will block ads.
        If you are watching on Android, I suggest newpipe or youtube vanced. Both will block ads.
          All the above is what I personally use and all 3 are open source.
          https://github.com/YTVanced
          https://github.com/TeamNewPipe/NewPipe
          https://github.com/gorhill/uBlock
            And I forgot the most important point in my initial reply.
            5)
              Thank you for posting this information and there is Apple products
              Look in the application store for ad blocker ( free version but I might upgrade to the pro version later after I have used for a while ) but you do have to use safari for it work correctly which I have just started using it and it works pretty good the videos do not get interrupt
              9 PC LCD Monitor
              1 Dell Mother Board
                Especially any improper spelling or unexpected punctuations, that will cause me to go into alarm right there!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                16 GB AData XPG Spectrix D41
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
