THINKPAD L390 password
    Re: Need help bios L390 1.36 computrace activated
    Originally posted by hoaca388 View Post
    Hi , thank you for your response
    i flashed the file with rt809 same probleme (blackscrenn with beep) :-(
      @Linux200
      If you intend to test everything that will be posted here, remember that an eprom supports up to 100,000 thousand recordings only.
      Please wait... I have already received your help request.
        Hi , thanks for reply same probleme with this file posted above black screen and bip (tpm initialization 0285) with and without a locked hard drive inside :-(
        @Linux200
        Post a picture of cover, I need the full model of the laptop.
        Via patch only these models:
        ThinkPad L390 (20NR, 20NS)
        ThinkPad L390 Yoga (20NT, 20NU)
          Originally posted by onizzbox View Post
          @linux200
          post a picture of cover, i need the full model of the laptop.
          Thinkpad l390 (20nr, 20ns)
          thinkpad l390 yoga (20nt, 20nu)
          20nus2w700 latest bios version 1.36
          i can reach windows
            need bios dump lenovo l390
            hello everyone! I have this laptop that won't turn on, when I plug in the charger I just see the power button LED flashing 3 times, the history of this laptop it had the bios password, I removed the bios chip to get the dump but my programmer stopped working, I put the bios chip back and I got this error, if possible a dump for this motherboard model : lkl-2 mb 18724-1 448 0fc03
            tanks
              Re: need bios dump lenovo l390
              tanks
              Its important to make a good backup. Make another two backups,compare them with a hex editor or some other file compare software to make sure both are the same,then post one of your backups. Not sure if the password can be removed though on this model by patching,you might have to use JTAG
                Re: THINKPAD L390 password
                OK,i have replaced bios chip and put my dump,now laptop turn one but i have password on bios configuration i can't change setting boot to uefi
                  this
                    Try
                      Hello guys, i patched the bios dump, but no success melody with black screen can someone please help me
                        What would be the laptop's initial problem, BIOS password?
                          yes sir the password, the type: 20NU-S0Y400
                            Post the BIOS with 32Mb
                              @zak53
                              Yes, it is possible to unlock it using my Autopatch. Post the BIOS with 32Mb
                              there is two chips BIOS 1 W25Q128JV, and BIOS 2 25q80dvsig
                              here is the dump of the BIOS 1 W25Q128JV
                                STEP 1: Flash and replace current BIOS with the generated patch file
                                STEP 2: Boot the machine
                                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                                STEP 4: Enter any character when asked for Supervisor Password
                                STEP 5: Press enter when it shows Hardware ID
                                STEP 6: Press space bar 2x when asked
                                STEP 7: Turn off machine
                                STEP 8: Restore original BIOS
                                STEP 9: Reset BIOS settings to factory defaulT
                                  i flashed the chip, but when i compare the patched dump with the programmed one it's not the same there is a deleted part as you can see in the screenshot
                                  I removed the chip from the mother board and i use XGPRO TL866ll PLUS
                                    this is patched
                                      this is patched
                                      Yes, i don't know why the file is not the same after the flash
                                        I managed to flash the patched dump with a good compare, but still the same melody with black screen
                                        When i put back the original dump the laptop work fine, but with password
                                          Try
