I have samsung plasma ps51e550d1r that powers on but doesn't display and the power light blinks 5 times, where to start looking ?
samsung plasma ps51e550d1r no display
Re: samsung plasma ps51e550d1r no display
so we were checking the boards for visible signs of damaged components and shorts and we found a few components in the y board and eventually got all the ones replaced we could see and detect as faulty after 2 or 3 attempts . now the situation is when power is connected the logic board led blinks 5 times in 5 second intervals for 30 seconds and stops and power led starts to do a double blink after 30 sec continuously . we get the 5v standby in the logic board. no vs and va in the y board. when we disconnect the bottom middle cable leading to the logic board the logic board led stays off and the power led 5 times again like original error. what can we check or try next?
we disconnected the y board and tested the vs and va and we got the correct readings . next we check the components on the x buffer board and found three shorted components 2 transistors and a diode we replaced them and connected everything except the y buffer board and it lead to the three components on the x buffer board blowing again.
what could be the fault now?
