Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Thread Tools Display Modes
Old 06-26-2021, 08:50 AM   #1
waldoalvarez00
City & State: Santiago
My Country: Dominican Republic
Line Voltage: 110v
I'm a: Knowledge Seeker
Default Missing 12v in asrock z77 extreme 4
Hi Folks:
I have this board and attached a GPU that created a short in 12v pciex port lines (the slot). Something smoked with white smoke but nothing looks burned. Around the VRM was some smell. No idea if from GPU or motherboard. Nothing looks burned from GPU or motherboard. I do however have many points where there should be 12v and there is 374 ohm to 12v atx line. I post image with blue circles where there are 0 ohms. I was thinking to bridge with wire as pictured by green line since I find no other component that could be damaged and assume maybe a cooper line got damaged. Any ideas??
This is the link for board view file https://easyupload.io/kz024c
Everything disconnected from +12v is connected between them. I tested with continuity. But reads 374 ohm to +12v atx input port.
waldoalvarez00 is offline   Reply With Quote
Old 06-26-2021, 08:57 AM   #2
waldoalvarez00
Line Voltage: 110v
Default Re: Missing 12v in asrock z77 extreme 4
Another thing, I pulled some mosfets from VRM (3 of them) and they are totally ok as measured by transistor tester. So I soldered them back into the board and tested they where well connected with the meter. And another detail is that q958 and q951 that work together read 0 ohm from gate to drain. But they read good when pulled. They are controlled by this chip I add datasheet on the link https://easyupload.io/ud0xio
Old 06-26-2021, 10:43 AM   #3
dicky96
Sun Seeker
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
I'm a: Professional Tech
Connecting a wire from 12V ATX to anywhere else that should be connected to that rail according to the boardview, would not cause any harm
__________________
Follow me on YouTube
Learn Electronics Repair
dicky96 is offline   Reply With Quote
Old 06-26-2021, 02:48 PM   #4
waldoalvarez00
Line Voltage: 110v
Quote:
Just powered it to try to measure some 12v points and noticed the superio (NCT6776D) is shorted and getting the 3.3v regulator from 5v standby to become super hot as well. I think I need to order a new one cause that for sure is an issue. Thanks! If after replacing it I see no 12vin those points I am going to put the jump wire to that inductor and see what happens. I hope the superio doesn't fries again.
Old 07-02-2021, 02:51 AM   #5
taxxin
taxxin's Avatar
City & State: bangkok
My Country: thailand
Line Voltage: 240v
I'm a: Hardcore Geek
Super IO always does this, i have 2 boards needs superIO replacing on gen3 gen4 intel boards
taxxin is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
