help to find Nippon Chemi-Con datasheet
    I need help to find the datasheet for a:
    Nippon Chemi-Con
    CE NM 85c
    180V 680uF
    30mm diameter, 51mm high, 10mm leg spacing
    on the top of the cap is a plastic top with "43SKH"
    Im trying to find the ripple current, Ive looked all through here:
    https://cdn.badcaps-static.com/pdfs/...d92625445c.pdf
    but it does not have anything for SKH or CE NM
    Re: help to find Nippon Chemi-Con datasheet
    According to the information you provided, this is a general purpose unit.
      Datasheets for general purpose part often or usually do not give the ripple current or impedance rating. General purpose parts are not intended for high ripple current or low impedance usage.
      PeteS in CA
