I just got a pretty nice Dell Lattitude E7450 laptop from a friend to try and fix. When the charger is plugged into the laptop, the light on the adapter immediately goes out. I disassembled it and took the board out. I put 3v to Vin at charge port and found that mosfet AO4435 was getting hot. That was the only component I found to get hot and there are no signs of damage to this chip or any component . There are also several caps that are grounded on both sides when testing for shorts but I can't tell if this could be by design, due to the bad mosfet, or other condition. Question is, how likely is it just this chip or should I be looking for other bad components?
Need help troubleshooting power circuit on Dell Lattitude E7450
Re: Need help troubleshooting power circuit on Dell Lattitude E7450
Do not apply voltage blindly, it can cause more harm. If you need to apply voltage, always start with a low voltage (Typically 1V).
I think the schematic is posted here:
Lattitude E7450
https://www.badcaps.net/forum/showthread.php?t=70511
1) are you using the original power adapter?
2) voltage at dc_in_ss ?
Originally posted by mon2 View PostI think the schematic is posted here:
Lattitude E7450
No worries, you'll learn along the way. If I may ask, do you have some background in electronics/soldering/using multimeter, etc?
Our first step is to try to rule out any obvious faults through visual inspection. Since you mentioned adapter going off as soon as you connect it, I suspect it may be a shorted capacitor (that is a common fault). Using a magnifying glass (ideally a microscope if you have one) Look around on the board and see if any of the small capacitors (brown bricks) seems to have a crack on them or have obvious discoloration.
We'll move onto using schematics and multimeter at a later stage.
Originally posted by Spider1211 View PostNo worries, you'll learn along the way. If I may ask, do you have some background in electronics/soldering/using multimeter, etc?
Ok great! A good magnifying glass will do if you cannot find a microscope.
Before we concentrate on the main rail, we want to rule out the possibility the other power supplies are not shorted. Set you DMM to continuity mode, connect the black probe to ground (just find a screw hole with copper around it and hook it there).
Using the red probe, poke all the inductors (grey bricks) and note the resistance value and report back. Each inductor has a unique name, something like PL100, etc (usually written next to it). It does not matter much which side of the inductor you poke, just make sure all power source is disconnected first!
For example:
PL700= .....
PL600= .....
By the way, just to confirm, your 30V power supply is adjustable? Can you set the voltage and current limit independently.
Originally posted by Spider1211 View PostOk great! A good magnifying glass will do if you cannot find a microscope.
For example:
PL700= .....
PL600= .....
For example:
PL700= .....
PL600= .....
• Inductor readings:
○ PL500 = 65.5 Ohms
○ PL700 = 0.2 Ohms
○ PL701 = 4.6 Ohms
○ PL101 = 3.69 Ohms
○ PL102 = (constantly moving, draining from 500k Ohms down and back up again)
○ PL200 = 446 Ohms
○ PL301 = 1.9k Ohms
Definitely have a short on main rail. PL101 seems low also. Let's figure out the mail short first.
Since you mentioned you did not see any physical damage, try injecting voltage on PL700. Start at 1V and 1A, see what gets hot. If you feel nothing, increase Ampere only (try 3A and move up to max you PSU can supply which I guess is 5A?).
If you still can feel anything, increase voltage to 2V and check again. In my opinion, its most likely either a capacitor or mosfet.
Edit:
Once you identify the shorted component and remove it, measure continuity on the inductors again. Make sure you do not apply power if you remove mosfets.Last edited by Spider1211; 01-02-2022, 02:43 PM.
Originally posted by Spider1211 View PostDefinitely have a short on main rail. PL101 seems low also. Let's figure out the mail short first.
Edit:
After trying the above, try removing PL700 and see on which side the short is.
If you are comfortable with it, try removing PU800 and check if the short is still present or not. This chip can sometimes fail and give similar issue to yours. Just make sure NOT to power the board with the chip removed.
Originally posted by Spider1211 View PostAfter trying the above, try removing PL700 and see on which side the short is.
I can't even find PU800 on the board. I'm starting to think the schematic does not match my board. I will try the above again powering for a longer time. But I think I'm going to remove PQ700 which is the AO4435 mosfet.
If you can't find PU800, try looking at the small black IC that has the following label: CD3301 (a quick google search should show you how it looks like).
Post a picture of your motherboard reference so we can crosscheck if its the correct schematic.
Removing PQ700 won't help much since it is just an input protection mosfet. You can try though. I have a feeling it might be the PU800.
Originally posted by Spider1211 View PostIf you can't find PU800, try looking at the small black IC that has the following label: CD3301 (a quick google search should show you how it looks like).
