Hi folks, happy new year!
I'm trying to fix this dell that turns on but it gives no display, just 7 beeps (CPU related code), visual inspection didn't reveal anything significant, after some measures i discovered that the board is generating all voltages except +VCC_CORE and VCC_GFXCORE_AXG this voltages are generated by the same IC PU700 checked the IC and VR_ON is high and the chip gets proper 5V power.
I thought the chip was defective and replaced it, to my surprise i got the same result with the new chip oops! checked the mosfets and seem OK, the resistance on the coils is about 4.3 ohm, then i checked the control signals comming from the processor VR_SVID_CLK, VR_SVID_ALRT#, VR_SVID_DAT all the signals are at 1.05v but no data transmission on the lines just steady voltage, for some reason the CPU is not sending the control commands, just in case i reflashed the bios chips (but not the EC as i don't have a suitable programmer) and nothing changed. PLT_RST# remains at low value but this signal can be controlled by EC and PCH, any idea for a proper diagnose without having to replace these chips?
Thanks in advance.
Thanks in advance.
