It turns on, but anywhere from turning it on until hours after logging in random kernel panics, screen going dark (but backlight still lit), and completely turning off happen.
Happens at idle CPU temperatures as well a 95+ degrees.
Doesn't matter what is happening, idling, running CPU/GPU/SSD stress tests, using web browser.
Memtest ran for 4 hours no failures.
Issue happens in SMC bypass mode.
Apple diagnostics says no problems.
Re-applied thermal paste.
No corrosion at all on the board.
I have tried running with no battery, only battery, battery and magsafe at the same time, problems occur during all scenarios.
I read that the 15" version has bad mosfets that fail over time, those unfortunately aren't in the 13"
