STR2A153 vs STR2A153D SMPS IC
    The device I want to replace does not have the 'D' suffix, but the replacement I have in my parts drawer does have the 'D'.
    I can't find any specific datasheet on the net for a 'D' variant. Do you reckon it's just slightly spec'd up and hence the designation: D?
    Re: STR2A153 vs STR2A153D SMPS IC
    Here is the data sheet
    https://datasheetspdf.com/mobile/938...ken/STR2A153/1
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Yes, thanks, I had the datasheet. But it makes no mention of a 'D' variant, hence why I was asking around if anyone had any experience with this SMPS IC?
      In the repair I'm doing it is used in a Pioneer Receiver VSX-529. The IC is rated at about 35W output. It directly drives the switching circuit - no external mosfet. I gather it is used in an auxiliary supply which must power the logic circuits etc of the receiver?
        On other versions the `D' stands for auto restart on OVP, TSD Operation
          Hi RJ,
          You might need to spell out those acronyms for me?
          And in terms of a SMPS, what does auto restart actually mean? If mains power was lost, and then came on again, I would have thought any SMPS would start up again. So I'm obviously missing something?
            I am looking at the STRA3A200 datasheet
            − Overvoltage Protection (OVP) : Latched shutdown or
            auto-restart
            − Thermal Shutdown (TSD) : Latched shutdown or
            auto-restart with hysteresis
              Thanks RJ. I think that does explain it most likely. "Latched Shutdown" is abnormal condition keeping the SMPS switched off; auto-restart where it does exactly that after the condition is removed.
