Vizio TV E470VL SMPS Flucuation Output Voltage
  • dholley
    Mr. Blinky
    • Jan 2022
    • 87
    Re: Vizio TV SMPS Flucuation Output Voltage
    Regarding R102, testing on side closest to filter capacitors voltage is 169, testing on side closest to IC voltage fluctuates between 79 and 112 volts . Testing at pin 3 of IC which I think is VCC voltage fluctuates between 9 and 11 volts
    • R_J
      • Jun 2012
      • 9535
      what about the voltage on D102?
      • dholley
        Mr. Blinky
        • Jan 2022
        • 87
        D102 testing bar / striped side fluctuates between 8 and 9 volts
        • R_J
          • Jun 2012
          • 9535
          Originally posted by dholley
          I just measured, there is NO 5 volt or 12 output. The 5 volt was fluctuating from 3 to 4 volts but is now 0 volts. The big capacitors were at 167 volts they are now at 171 volts. I don't know what happened.
          Are you getting anything on the 5 volt line or is it still 0 volts? If it is 0 volts I suspect the u101 is bad and not switching at all.
          • dholley
            Mr. Blinky
            • Jan 2022
            • 87
            It is now fluctuating around 4 volts
            • dholley
              Mr. Blinky
              • Jan 2022
              • 87
              I appreciate your help RJ. I’m signing off for tonight, but will be happy to provide any additional information in the morning. Thank you!!!
              • R_J
                • Jun 2012
                • 9535
                If you are getting around 4v on the secondary, you should be getting around 18v on D102. Check that feedback winding on the transformer, check R105, Check D102. If these parts are good then either C104 is bad and not charging
                That feedback circuit also supplies Q101 collector which is a regulator/switch that supplies vcc2 (on its emitter) to the pfc ic U601
                • dholley
                  Mr. Blinky
                  • Jan 2022
                  • 87
                  Re: Vizio TV E470VL SMPS Flucuation Output Voltage
                  1. Can you tell me how to test the feedback winding on the transformer?
                  2. R105 is 10.01 ohms tested in circuit
                  3. D102 is fluctuating between 8 - 9 volts
                  4. C104 - with my ESR meter is says it is a good cap with low esr
                  • R_J
                    • Jun 2012
                    • 9535
                    Just check the resistance of the winding, it should check around 1Ω. D102 is a diode, use diode test on your meter to check it. The ic shuts down with only 8 volts of vcc
                    • dholley
                      Mr. Blinky
                      • Jan 2022
                      • 87
                      In measuring the transformer from the bottom side of the board, hot side, I put my lead at the end of the transformer leg nearest the IC and put the other lead on the next closest leg, 0.50 ohms, i used the same method on the opposite end 1.0 ohm.
                      D102 - with the diode test of the multi meter, OL one way and 0.536 volt the other
                      • R_J
                        • Jun 2012
                        • 9535
                        The diode check ok, I just had a closer look at the top third picture and C114 looks damaged? or is that black from something else?
                        • dholley
                          Mr. Blinky
                          • Jan 2022
                          • 87
                          Oh my gosh RJ, GREAT JOB!!!!!!!!!!! It is indeed damaged!!!
                          • dholley
                            Mr. Blinky
                            • Jan 2022
                            • 87
                            Pictured attached
                            • R_J
                              • Jun 2012
                              • 9535
                              Is the capacity marked on the other side? if it is it is likely a 1kv cap, replace it with a 2kv is recommended
                              • dholley
                                Mr. Blinky
                                • Jan 2022
                                • 87
                                there is no marking on the other side, but it looks like C106 which is near the big filter cap, next to the red transformer. C106 is a 1kv
                                It looks like, C610 not C106
                                C610 is 101k, 1KV. Do you have a replacement recommendation and they are non-polarized correct?
                                • dholley
                                  Mr. Blinky
                                  • Jan 2022
                                  • 87
                                  have another 101k 1kv on another board, do you think it would be ok to install it and see if that fixes this boad?
                                  • dholley
                                    Mr. Blinky
                                    • Jan 2022
                                    • 87
                                    the Damaged cap measured approximately 90 PF, if it is a 101k that is pretty close to the right value
                                    • dholley
                                      Mr. Blinky
                                      • Jan 2022
                                      • 87
                                      I replaced the cap with one from another board. It measured approximately 115 PF. Powered up the board and there is still fluctuation at the output pin and at vcc
                                      • nomoresonys
                                        • 12093
                                        • U.S.
                                        #39
                                        Touch up some of those solder joints.
                                        Did you touch up those suspicious joints? just in case you missed the post.
                                        • dholley
                                          Mr. Blinky
                                          • Jan 2022
                                          • 87
                                          I re-soldered a couple, can you tell me where exactly that needed attention?
                                          • electron_jj
                                            Panasonic TH-L42D25A checking the PSU output voltage
                                            by electron_jj
                                            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                            08-29-2021, 08:13 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • David Miteff
                                            NM-D521 rev. 2.0 output voltage on CPU coils seemingly low
                                            by David Miteff
                                            Hello, guys!
                                            As the title says - the board is NM-D521, on the input of the CPU coils I read 1.2-1.3V, which should be normal, but on the output I read around 0.6-0.8V. The laptop bootloops with no picture.
                                            As of right now I don't have a thermal camera, so I can't confirm a shorted or partially shorted CPU chip. Do you have any other suggestions as of why the output voltage might drop like that?...
                                            12-30-2024, 07:02 AM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • Ri5ux
                                            Playstation 5 2 Second BLOD, F3501 Voltage Output Question
                                            by Ri5ux
                                            Hi there, just wondering if anyone out there who has a semi-working or working PS5 board could check the output voltage on F3501's buck converter for me, with and without power. I have 12V on the input, fuse not blown, no output voltage on that IC, with or without power, and no shorts present.
                                            Symptom: 2 Second BLOD
                                            Testing: All other rails seem present. APU, SSD, South Bridge, and RAM confirmed to be powering up using a thermal camera. Monitoring the current draw of the 12v rail shows a somewhat normal boot cycle of the south bridge. Jumps up to 300ma, and down to 0....
                                            09-09-2023, 06:57 PM
