Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 05-31-2016, 06:47 AM   #1
carl12
City & State: New York
My Country: United States
Question Repairing a Dell H535T Motherboard
I need to repair a dell motherboard, that has two caps bulging on top.
The caps are near the first cpu/memory banks and the model is:
SANYO 1500uf 6.3V - 105 S.E. 99 WF
I'm not finding the same model, can you give some advise another cap to replace them?
The S.E. 99 has any special meaning?
In case I can't find a good replacement, can I change them for example for 2200uf 16V - 105, or is a very bad idea?
Thanks!
carl12 is offline   Reply With Quote
Old 05-31-2016, 12:57 PM   #2
carl12
Default Re: Repairing a Dell H535T Motherboard
Sorry another question, what could happend in case i found some cps 1500uf 6.3 but low ESR instead of ultra low ESR?
Thanks!
Old 10-21-2016, 08:36 PM   #3
waldoalvarez00
City & State: Santiago
My Country: Dominican Republic
Line Voltage: 110v
I have the ones you need but I don't have the ones I need. I always try to put the same capacity ones but think theoretically you can put higher capacity at the input of the VRM. At the output not really sure. I know main parameter of a buck converter is the inductor (choke) for ripple current as in here http://www.daycounter.com/LabBook/Bu...quations.phtml now capacitors resist change in voltage. AFAIK if you put them higher resistance to voltage change should be higher. But then IDK if you are dealing with a buck converter. Likely but not sure.
waldoalvarez00 is offline   Reply With Quote
