Lenovo G50-30 no POST on powerup
    Re: Lenovo G50-30 no POST on powerup
    @mauda, i dont know which schematic you are refrerring to but my schematic shows pu402 pin2(PG) GOES TO alw_pwrgd through a pull up resistor from +3valw.
      This is the diagram i have.
        Omg, I am very sorry.
        I have a different motherboard:
        ZIWBO/B1/E0
        LA-B102P Rev: 1.0
        2014-06-12
        Should I start another thread on this forum?
          Yes, this thread is for NM-A311 and all advises are based on that mb which will mislead you. Better start a new thread.
            OK, I started a new thread here https://www.badcaps.net/forum/showthread.php?p=1020481.
              Hi all, I have the same laptop with this issue. In my case the IO chip, IT8586E , was burnt. The chip was recovered from lenovo NM-A271 and programmed with a dump from this forum. Someone has found a solution to this defect?
                I find the problems, someone changed the ram memory and it was not compatible, the laptop is working now.
                  I've got an G50-30 NM-A311 rev 1.0 mobo with no display - only led and no display.
                  Found burning hot KBC chip. Bought a mobo which comes to a backlight, capslock working, cpu seams heating up - but no display.
                  Replaced KBC chip from bought mobo - and nothing - no backlight, capslock.
                  Replaced BIOS chip from bought mobo - starts up, shutes down, caplock working - but nothing on display but backlight.
                  Tried differend found bios'es , but backlight and capslock work only in this from a bought donor board.
                  Tried to make a new bios from a manufacturer site - nothing,
                  tried to clear ME region with clean one - nothing.
                  What else can I try, or how to check if CPU/PCH is dead?
                    So I'm stuck on this:
                    1. Original bios from mobo with cleared ME region - Black lcd with polarisation, works HDMI (with plugged LCD), VGA - only when LCD disconnected,
                    2. 2nd bios - withe ME cleared - same situation but LCD has backlight.
                    So different bios different LCD behave.
                    Can it be KBC needs reprogramming somehow?
                      Yes, kbc is programmable.
                        Today I've changed KBC for new preprogrammed one.
                        Same story - so my old KBC was acting same as new one.
