Need help in identifying a component on a GPU
  • danny1ro
    • Jun 2021
    • 17
    • Romania
    I have searched the forum for a boardview that would help me identify a component on my Gigabyte rx580, but no luck so, here I am with a request for help.
    The story is simple, I wanted to dust it off and my father was near the compressor and he offered to do it, but somehow knocked or blew off a component. Now I'm trying to find what that component is, so I can put it back in its place. I found the one that was there, but it has a chip on one of the corners, with some layers inside showing.
    I looked around the board and found another one just like it, please check the photo.
    If you can point me also to a tutorial or something that would help me identify stuff like this in the future I would be very grateful.
    Thank you!
  • petehall347
    • Jan 2015
    • 4424
    • United Kingdom
    Re: Need help in identifying a component on a GPU
    1.5 AMP FUSE measure it and look up size code .
    • danny1ro
      • Jun 2021
      • 17
      • Romania
      Thanks for the reply.
      I did search for the component in some databases, but I found multiple thinks listed under the letter "K".
      The table I looked at is at the following link: https://smd.yooneed.one/code4b00.html
      I don't know how to measure a fuse, but I will look for a tutorial. Also, when you say to look up size and code, what other code can I look at?
      Thanks!
      • petehall347
        • Jan 2015
        • 4424
        • United Kingdom
        will be something like 0603 .. best wait and see what others say it is ,,but it is marked as f400 suggesting it is a fuse .
        • danny1ro
          • Jun 2021
          • 17
          • Romania
          I also measured both now and the readings for both of the components are 1.2 on the "200" scale of my multimeter. Would you consider that the broken part is still usable?
          Thank you!
          • petehall347
            • Jan 2015
            • 4424
            • United Kingdom
            now put your meter leads together and then deduct the reading from 1.2
            • danny1ro
              • Jun 2021
              • 17
              • Romania
              that would leave me with 0.2, which is about close to that 0.17 I saw in the specs for the model you mentioned.
              would it be safe to use again the component which has a chipped corner? if not, I found new ones on aliexpress, but it will be a long wait until I get them.
              thanks again for the help!
              • petehall347
                • Jan 2015
                • 4424
                • United Kingdom
                if it will solder back on give it a try
                • danny1ro
                  • Jun 2021
                  • 17
                  • Romania
                  it will, only a bit o plastic on the side is broken off. I'll give it a try
                  • bensatrio8
                    • Jun 2021
                    • 10
                    • Indonesia
                    it is shown 200mA 24V from the schematics, the size is 3216 or 1206 smd fuse.
                    I am also in the middle of repair attempt bunch of rx580s, hope that helps and goodluck with yours.
                    • danny1ro
                      • Jun 2021
                      • 17
                      • Romania
                      thanks, I think I found the right part on aliexpress, but I'll try to put the old one back there.
                      • waldoalvarez00
                        • Dec 2015
                        • 57
                        • Dominican Republic
                        That fuse reads totally fine.
                        • thesame
                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                          by thesame
                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                          02-27-2024, 04:31 AM
                        • chth96
                          How can I identify varistor which have been blew up?
                          by chth96
                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                          So It seems that glass fuse and varistor have been blew up.
                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                          Is there any way to identify varistor type in my sega saturn PSU?
                          Any reply would be appreciated.
                          EDIT:
                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                          11-26-2023, 08:52 AM
                        • debidoobs
                          RX580 GPU have all the right voltages but won't turn on
                          by debidoobs
                          Hi Guys,
                          I just replaced 2 blown fuses on the 12V rail of a RX580 sapphire 8go even though i didn't find any sign of shorts on the 5V, 3.3V or 12V with my multimeter. I don't know the history of the card..
                          i followed step by step the video from TECH Cemetery (https://www.youtube.com/watch?v=supu7YeNTfw) but when on his RX580 sapphire 8go he doesn't have VCORE mine does but won't turn on .. I watched many video but i don't find same situation i m facing. So im clearly lost because all measurements steps i did on the GPU are fine. I have a B550m, a 550W psu, 16go...
                          02-25-2023, 10:35 AM
                        • freakorio
                          Need Help To Identify Component on Ymain LJ41-05120A
                          by freakorio
                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                          05-21-2024, 02:32 AM
                        • baiceanu_stefan
                          nm-f251 Schematic, boardview or help identify componente
                          by baiceanu_stefan
                          Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                          04-24-2024, 12:49 AM
