Dell E5440 completely dead
    Re: Dell E5440 completely dead
    Remove PU701 and check. It easier and less time consuming than the other methods. Just do not power the board with the chip removed.
      Once i Had a partial shorted 5V Rail which was also drawing almost nothing. However the VRM Controller got Mad hot. Case solved.
      But yeah i won't expect a massive consumption.
      FairRepair on YouTube
        I removed the PR400 and see 20Ω only from the side that is connected to PQ400, the other side is fine (~1kΩ)
          Check PQ402. Also try removing PU402 and check again. 1Kohm seems a bit low.
            So it is indeed +SDC_IN which is shorted. Still PU401 und PU701 Most suspicious in my opinion
              Check PQ402 and PQ400. Also try removing PU402 and check again. 1Kohm seems a bit low.
              Btw, did you also remove PU701 before removing PR400?
                No, only PR400 removed, i want to keep the PU701 option last
                I'm not too good at soldering QFN
                  Resolder PR400 and remove PQ400. Check which side is 20Ohm. If Drain side (pin 5,6,7,8) of PQ400 is 20Ohms remove PU701.
                    Resolder PR400 and removed PQ400 and now the funny part begins.
                    The 20Ω remain on all three Source traces.
                    Drain and Gate are fine with 40KΩ and 8.4MΩ.
                      Remove PU402 and check again. If it's still same then remove PU701.
                        Removed PU402 but the 20Ω remain on Source traces of removed PQ400
                          PU701 it is then, as suspected initially.
                            Ok, gonna try replace it and report back
                              Just remove pu701 and check resistance first. Also make sure not to power the board without the controller chips soldered!
                                Goodmorning!
                                I resolder PQ400 and PU402 and removed PU701.
                                The 20Ω on all Source pins of PQ400 are gone, now it's ~220KΩ
                                Are we ok with it?
                                  Thats great! This confirms a faulty PU701. Replace it and you should be good to go.
                                  Also, with PU701 removed recheck the point where you measured 1Kohm initially and see if its still same
                                    Now shows several MΩ, probably fine?
                                    Also I have CD3301B available from donor board, report in a while
                                      Very fine. Good luck!
                                        Ok, solder it succesfully and i see power LED light on BUT only for 1 second, then goes off.
                                        Seems like i have another issue or something is not soldered right?
                                          Dell will power cycle a few times before booting (usually around 3 times). Try this: plug in charger, wait 1 second then remove charger. Wait another 1 second then plug charger back in and try to power again (it should power cycle then boot)
