Re: Kind of a different question...
This is a great point I would not have thought about doing this to find out if you had an issue with stray voltage on a device to do this to find if it is going to be an issue or not
switching power supply that only have a two wire connector I find is a little stupid in my estimation because of what you have experienced that you might feel a tingling sensation on a metal part of the device is not acceptable in my book
Yes this might be a little off topic but I have also seen this happen as well
You can also have this on air conditioning compressor that have an issue with the varnish breaking down on the windings and leaking voltage into the oil and when it first starts happening it sometimes not enough to trip some GFCI outlets but when it gets worse then it will trip the GFCI outlet that someone has a bad grounding pin or has cut off the grounding pin on the power supply cord
Originally posted by eccerr0r
View Post
