Latitude 7380 Kylo Ren 13 CS MLK 17945-SB
    Re: Latitude 7380 Kylo Ren 13 CS MLK 17945-SB
    Originally posted by SMDFlea View Post
    try this one.. if it doen`t work i give up .
    Ok, I flash Insp 7580 ME_Clean.bin, and there is a result, before that, when I pressed the power button, there was not any reaction, but with this BIOS the power button lights up, the keyboard backlight and the tuchpad are also, on display is no picture, and after 7-10 seconds everything turns off, and no longer responds, if I disconnect the battery and the bios battery, everything can be repeated again ...
      It will reboot and shut down on its own,maybe 3 or more times,give it 5 minutes at least
        No, it did not help, the laptop turned off after 10 seconds and did not turn on again, it stood like this for more than an hour.
          no more ideas?
            no more ideas?
            post front and back motherboard clear photo and close cpu processor photo and need processr number and touchpad top panel photo now i give file
              Hi, I took the photo you asked for, if you need anything else, let me know.
              FOTO 886H97B701417
                FOTO 886H97B701417
                this 100% worked file, wait and check using dell original charger. charger
                  2 yellow and 1 white blinking (cpu error ?)
                    check cpu core votage
                      please help. no display, Dell inspiron 7380
                      Service tag 4mx15p2
                        Service tag 4mx15p2
                        nnkkkkkk
                        Become a Badcaps supporter
                        Thanks to all supporters.
