Pls. Anybody can give me an schematic for asus k53sd rev.5.1
asus X53E/board K53SD rev. 2.1/ self start need schematic
have this one asus X53E/board K53SD rev. 2.1/ and it self start and not fully reage to power switch. i ffind taha it have some short on main power on LVDS connector because i see some self-solder in connector.
cannot find schematic to fully diagnose it. any help with it?
board code is hannstar J MV-4 94V-01122 E89382
i found that it can have same board as acer 8942/8943Last edited by ktmmotocross; 12-26-2014, 09:22 AM.
Re: asus X53E/board K53SD rev. 2.1/ self start need schematic
maybe its simmilar but this asus have other ics and no board marks a and some ic are not the same
But i think i have some broken contact. when i twist the board in some direction it works normally. do somebody know what ic or part can have that loose contact? i dont wanna bake whole board when it works
sometimes it start without display with all leds come and restart, sometime it wont start but have all basic voltages, sometime it start ok. what do u think what ic can be doing this?Last edited by ktmmotocross; 12-26-2014, 10:42 AM.
In the other thread, I have the Asus K53sv mobo, also no marks and no schematics.
I was hoping you were right about the Acer board.
The onliest loose contact item I would suspect is the power plug or direct related components.
I try to help were I can with schematics, I f you symbolize that with a trashcan, maybe I should not react anymoreLast edited by hansie55; 12-26-2014, 10:48 AM.
Re: ASUS k53sd rev 2.3 schematic please
only ASUS K53SD REV 5.1 (69N0KBB10F01P) - BoardView
http://**************/load/noutbuki/platforma_asus/asus_k53sd_rev_5_1_69n0kbb10f01p_boardview/313-1-0-25010
Originally posted by hansie55 View PostThis you need to check?
Have someone the correct one please? My Asus looks dead.
KTM , seems you got some problem near the on off connector . i had one asus making this , a ROG computer , but also apllying a pressure on that corner will make pressure until almost half the board , even if its much less than in the corner but will affect several solders . chek carefully on macroscope for broken solder joints.
Originally posted by darkwolf1945 View PostI need a schematic for a similar mobo hannstar mv-4 94v-0 of Asus K53SV but is for AMD processor, not for Intel like the pdf schematic appended here.
Thanks for your help.
