It seems on most all of the Epox boards I have, that once random BSODs start, and I RMAed the boards the first time, most of the boards still did not work when they came back. I ended up RMAing 3x crucial DIMMs to fix the problems on a couple of boards. Now that I'm replacing the caps myself, I only replaced 5 on this first boards, the only one that was showing random crashes (only in 3D games), but it seems it still crashes now and then. I wonder if a stick of memory flaked out because of the caps, or if some of the other non-buldging caps are still suspect.
Memory trouble?
Crashing only in 3D games can be a power supply problem and/or if overclocking the processor, not a high enough Vcore value or you overclocked the processor too much.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
You did not say whether you tested the dimms before you returned them. Anyway, for the future i would recommend the following free utilities to test sticks of Ram. Test them on a good board though because bad power to the ram would show up as memory errors anyway. I use them all the time before i install the OS on a new PC.
http://www.simmtester.com/
http://www.memtest86.com/
whether bad caps could permanently damage ram (with the exception of shorts and fires), i would like to know also.
