Maybe, somewhere, there's a capacitor brand that's even worse than GSC. In fact, I doubt there isn't. Any examples???
Anything worse than GSC???
Re: Anything worse than GSC???
A failed GSC... Okay, CapXon... seriously, I've replaced more of those than any other capacitor in TVs and monitors. Rubbish!Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
GSC/Sacon is the worst IMO. Fuhjyyu is a close second. Teapo is probably next.I love putting bad caps and flat batteries in fire and watching them explode!!
"Chhsi" seems to be as bad.
And 1000 uF+ Lelon is in a similar league.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -Mà mismo
The absolute worst is Rulycon (the fake Rubycon). The eletrolyte in those caps will break down regardless of whether they are run near their limits or not. In fact, they will go bad without being used.
BIG GAP
Second place I award to Stone caps. They will bulge at the slightest presence of heat.
A not so distant third, I would say Sacon FZ and maybe Evercon too (but not GSC). While they may be the same company, GSC *at least* don't go bad just by sitting around and they don't make a loud popping sound like Sacon FZ does when they fail.
I still have a Jetway N2PAP-LITE motherboard (circa 2003) with the original GSC ME caps. Works fine. I use it every now and then to test hardware and play some older games.
Fourth: CapXon. Heat them up a bit, and they'll hatch.
Fifth: All other crap caps. I don't consider Fuhjyyu that bad. Sure there were lots of failures in the early Antecs, but keep in mind that those older Antecs had retarded fan speed controllers, so it's not all Fuhjyyu's fault.
I have a Macron Power MPT-301 PSU that originally had all Fuhjyyu caps. Got it for free because the fan was stuck. The stuck fan caused some serious darkening of the PCB near the secondary heat sink. Guess what? - Those Fuhjyyu caps that were near it were bulged, but those that were a bit more far away were not. I fully recapped this power supply in 2008 or so. This year, I finally tested those Fuhjyyu caps. The bulged caps obviously tested bad on ESR, but the non-bulged ones tested fine - that's nearly 4 years after they have been pulled out of that power supply. So Fuhjyyu is far from being the worst.Last edited by momaka; 05-08-2012, 09:31 PM.
Originally posted by momaka View Postbut keep in mind that those older Antecs had retarded fan speed controllers, so it's not all Fuhjyyu's fault.
The fan controller for the outer fan is one of the worst on the planet!ASRock B550 PG Velocita
Originally posted by RJARRRPCGP View PostLike *cough cough* my 2005 SmartPower 2.0 500W.
But yah, the way they come set up from the factory is pretty bad. It causes them to run hot even under a light load, putting similar stress on the components as running it at near 100% all the time.
Originally posted by momaka View PostThe absolute worst is Rulycon (the fake Rubycon). The eletrolyte in those caps will break down regardless of whether they are run near their limits or not. In fact, they will go bad without being used.
I have an old ISA card with GSC caps on it. I don't know how old the card is, but the caps are still good.
The worst caps I have seen are Jackcon, these, and "SS" brand caps, as shown in the pictures below.
Originally posted by Pentium4 View PostAnd CapXon are pretty bad but seem to do decently in power supplies.
Open up any recent (past 5 years or so) Fortron ATX PSU, or one based on a FSP (like almost all Zalman, most be quiet, some Cooler Master, ...). You're guaranteed to find bad CapXons, even if the unit isn't even 2 years old..
Same thing happens in a lot of LCD monitor PSUs.
CapXon seems to be the modern capacitor plague for PSUs of any kind, much like Sacon was (is?) for graphics cards.. (or Fuhjyyu for Antecs)
They'll last a bit longer than 1 1/2 years till they start to bulge. By the time the 2 year warranty runs out, it's just a matter of weeks or months till the device stops working properly.
For recent Fortron PSUs, it seems like there's always a 25V 100uF cap in the 5VSB circuit that dies first, preventing the PSU from starting up (ticking or completely dead). Most of the time, some of the secondary side caps are already puking as well (oddly enough, the ones on 3.3V seem to go first)
edit: @ lti: that's not an ISA card.. that's the controller board out of a CD-ROM drive lolLast edited by Scenic; 05-09-2012, 11:31 PM.
CapXon are the worst in power supplies! Never, ever say they are good!!! I have pulled loads of them from LCD TVs and computer PSUs. They bulge like nothing else after about 2 years. They are completely incompetent when it comes to engineering a good cap.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by Wester547 View PostHas anyone here seen CapXons bulge if used as primary capacitors in PSUs or just on the secondaries?
Also, IIRC, there was a picture somewhere (not sure if on badcaps.net or elsewhere) showing the 2 CapXon caps of a PC PSU completely burned, and it wasn't the MOVs or anything else that caused it either - it was the CapXons.
CapXon caps also like to go O/C or high-ESR when used on the primary of a PSU with APFC.
