Thank you to the guys at HEGE supporting Badcaps HEGE HEGE DEX Chart
bad cap manufacturers - please post yours here
    not sure of the brand but the only markings is a logo of saturn tilted made of an e.
    same unit has bad jun-foo caps too.
    its an allied 400w atx psu.
      gsc is another that i see lots of
      they just go open or high esr with no outward signs of failure.
      like the g-luxons.
      if your board is unstable time to get out the scope.
        been seeing bad su'scon caps in mag lcd monitors.
        watch for them in mobo's
          GSC
          GSC - These are used on Leadtek boards. Silver caps with Green wrapping and Gold writing. 1000 and 1500 6.3V are key ones to go but be aware that the 330 6.3V ones also leak. the 330's are silver caps with purple wrap and gold writing. my motherboard and video card were bought around october 2002 as a time reference.
          Have some pics lurking at my webspace. Beware 56kers if u click on the pics. they are all 1Mb plus.
          Sureality Bytes
            G-Luxon silver cap with green coating and grey writing. 1500 6.3V going bad on a ECS K7S5A. My uncle blew a ECS K7S5A mainboard the other month. Bad caps and a shorted component. That had most of the power rail 1500 caps bad. 6-8 i think out of a cluster of 10.
            Sureality Bytes
              tocon type lr
              looks like all the other cheapo low esr caps.
              common in speedstream gear.
                Regarding Sanyo caps, I have 5 soyo slot 1 boards on the lan. I was worried about them but they all have sanyo caps. They have been running office hours daily for several years. Stable as hell even in win98 lol . No visible signs of any cap problem. I used to think that sanyo was not a good company considering their consumer goods. But their AA nimh 2100mah rechargeables are a favourite of mine and rate quite high in comparison reviews. They have also made a high tech CDR blanks plant in greece. Funny how some brands I used to consider not good are producing amazing stuff on the component side - Hyundai/Samsung etc.
                  GSC 1200uf 6.3V Y25A (green with gold text)
                  GSC 1000uf 6.3V T27C (black with gold text)
                  I have 3 dead Giga-byte boards with the above GSC caps.
                  OST 3300uf 6.3V 0212 (dark blue or purple with gold text)
                  G-Luxon 1500uf 6.3V 203B(M) (green with silver text)
                  I have 1 dead Elitegroup with the above 2 caps.
                  GSC 2200uf 10V T19A (green with gold text)
                  And finally i have one dead EPOX with the above GSC cap.
                    another BAD cap maker
                    sorry, wanted to report a BAD caps maker, but it 's already in the list (above)
                      bad caps on shuttle av11 board
                      on my shuttle av11
                      caps 2700 uF 6.3 V made by Gloria
                      all are bad
                        As my second official post, I would like to add Wendell to your list.
                        PhyrPhly
                          I'm not sure if the denials issued by Taiwan capacitor makers are all true because http://www.careyholzman.com/caps/images/caps2-4.jpg shows a reprint from the Nov/Dec 2002 issue of Passive Component Industry magazine where one manufacturer, Jamicon, claimed that it obtained its electrolytes from Sanyo, but Sanyo denied this. OTOH I've read from other sources that Teapo caps have always been good, and I haven't seen any bad ones.
                          A couple of Fuhjyyu caps in my 2-3 year-old 300W Antec started to bulge a few months ago, one black, one blue, but all the JEE brand caps in my 4-5 year old Powmax tested OK with an ESR meter and showed no bulges or leaks.
                          What capacitor company makes dark brown caps marked with the letter "M" where the lower legs of the letter are turned inward? I've never seen a bad one of these.
                            Unless I'm mistaken, those are Matsushita, aka Panasonic.
                            --Randy
                              here is a photo of panasonic FC with the M showing
                              ----> Thread Split and wigyori's Zida T810B-SE mainboard, filled with Licon caps moved to "All others motherboards" forum
                                Re: bad cap manufacturers - please post yours here
                                Just adding another brand: Jun Fu
                                I found it in an old no-name PSU I scrapped 6 months ago because it would not turn on anymore... Turned out it was due to bulging Jun Fu and Rulycon caps...
                                It is a 10v 2200uF cap, on the backside marked: WG105°C 0105
                                  Epox ep-8k3a
                                  2200uF 10V 10mm [13] GSC
                                  1500uF 6.3V 10mm [2] GSC
                                  1200uF 6.3V 10mm [6] GSC
                                  1000uF 6.3V 8mm [6] Teapo
                                    Dst is another crappy brand. They appear on some older Slot 1 QDI boards. They're usually not bulging from the top but from the bottom - so it's not so easy for inexperienced user to see that they're bad.
                                      thanks list is updated
                                        Here are some photos.
                                        Tayeh, Licon, G-Luxon, Jackcon, Jackcon, DST, DST, Jackcon, JPCON
                                        Close view of the DSTs - the smaller one has flat top but the bottom came out:
                                        Canicon, Jackcon, JPCON, G-Luxon:
                                        Misc. other crap - bad mosfets, mosfet drivers, VRM controllers, serial line drivers, etc.:
                                          I saw a new one today, Skywell. Was on a Geforce FX 5200 card that came in a Dell tower, could not see any brand information on the card itself. It had 4 Skywell 1000uf 16v, 2 had blown, and 1 OSCON 510uf 4v. The cap was dark blue and gold with the brand written horizontally. The monitor would lose video signal after about 5 minutes, replaced with oscons that I robbed from a mainboard and it works great.
