KZG - KZJ - Same Electrolyte
    Re: KZG - KZJ - Same Electrolyte
    Originally posted by Pyr0Beast View Post
    What is the DC -current- through a charged cap?
    --> 0
    And some leakage yes.
    What is the total current through the cap?
    + then - then + then - then + then -
    What is total voltage on the cap?
    + then + then + then + then + then +
    Wrong.
    Voltage is in referenced to some other point.
    - The AC and DC are referenced to different points.
    If the DC is at +12v then the Zero Volts for the AC is at +12v DC.
    As the DC results in zero current it doesn't make a lick of difference what it is because it is not causing any electrons to move inside the cap.
    Insofar as any electron movement [current] inside the cap the DC volts = zero.
    Mann-Made Global Warming.
    - Dr Seuss
      Does not need to be. Voltage is mere potential between two points. Here we are speaking about voltage on capacitor leads.
      Zero Volts for AC can be on 12VDC
      Or 0VDC with inverted phase.
      Or anywhere in between if you calculate zero voltage from Pk-Pk or RMS voltage.
      AC does not need to have 'zero Volts' anywhere as it is relative.
      And DC filer on oscilloscope doesn't give a damn about any DC potential and just shows AC waveform.
      As I said before. If ripple voltage never causes cap to go reverse biased there is no harm.
        When you gain an understanding of what voltage is you might begin to understand caps.
        - Dr Seuss
          You just proved it does need to be.
          - The two points.
          - Point 1 - The "Reference"
          - Point 2 - The point that is some value "Relative" to the reference.
          I'm glad you caught that.
          And that filter is a CAPACITOR.
          - So you've just provided an example that shows exactly what I said is true.
          Voltage doesn't go through the cap, current does. <<- Why is this hard to understand???
          It's also current that makes the pretty picture on the scope.
          There is no DC current through the cap.
          There is AC current through the cap and it reveres directions.
          - And just like with the scope, it doesn't give a damn about any DC potential, it just passes AC current.
          In fact if it didn't -> the Ripple wouldn't be filtered out of the circuit.
          - Dr Seuss
            - The two points.
            Both are completely relative to each other. Two points is all you need. Knowing which is which is just polarity or phase inversion issue.
            Where would you put reference on charged unpolarised cap ?
            Yes it is. Exactly because it removes all DC bias and allows you to observe pure AC.
            Now you are just silly.
            Zero volts or zero cross for AC can be anywhere you like. Think why it is like that.
            You can subtract from DC, you can add to it or you can modulate it, having adding and substracting averaging at zero of + or ground line.
            Alternating voltage passes easily. So does DC but only until cap is charged.
            Scope measures voltage, not current. If you want to measure current you need series resistor which will have some potential across it which you can then measure.
            Nice that you figured it out.
            Now do the same with voltages:
            There is DC voltage
            There is AC voltage
            Substract max. AC value from DC voltage and you will get lowest and highest voltage on cap and you will know if cap gets reverse biased.
            It gives a damn. Because it is polarised.
              You are too lost to waste any more of my time with.
              - Dr Seuss
                I think some of you guys need to start some sort of US based cap company and sell to TopCat.
                  I was thinkin' go to Mexico for the cheap Labor and form the Mexi-Con capacitor company.
                  - Dr Seuss
                    ~ jibberish ~
                    You are trying to mix the AC and DC as if they are one component and that's not the proper way to do a circuit analysis.
                    They way you think sending POT and DSL through the same wire would NEVER WORK because they would mix.
                    - That isn't how things work.
                    - Dr Seuss
                      I would say quite the same for you.
                      Yes I am. Because that is only thing what matters at capacitor chemistry.
                      Now you are just ridiculous.
                      I have VDSL wired that way with POT phone on the same line, WORKING !
                      32Mbit synchronisation !
                        YES, it does work.
                        - But if what you say about voltages on caps was true, it wouldn't.
                        - And THAT is what is ridiculous.
                        - Dr Seuss
                          Originally posted by PCBONEZ View Post
                          YES, it does work.
                          Too bad as it seems you don't get it. Eh. I have tried.
                            And the only way electricity affects chemistry is by CURRENT.
                            There is AC current. [And the DC voltage is does NOT affect it.]
                            With the exception of leakage there is no DC current at all.
                            - And in lytics the majority of leakage is due to the molecules that move in the healing the Oxide layer.. from the damage caused by the AC current.. .. the AC current which isn't affected by the DC voltage at all.
                            You are trying to add the AC and DC together as if they are one component and they are NOT the same component any more than the DSL and POTs signal are when they co-exist in one circuit.
                            - Dr Seuss
                              You stick that scope on the DSL + POTS signal and it will display the SUM.
                              Neither the POTS nor the DSL would work on that signal.
                              They use filters in the down stream device so it only gets one signal.
                              You stick that scope on the DC + AC on a filter cap it will display the SUM.
                              But the cap -IS- a filter to DC. It blocks it. - There is no DC current.
                              That means the only current passing -through- the cap that could possibly affect it's chemistry is the AC current, which is due to Ripple voltage.
                              - Dr Seuss
                                DC current is not needed. DC potential is.
                                Same with lead acid batteries. They loose their potential - they degrade.
                                  And its effect is limited by DC bias.
                                    No, it's not..
                                    It's self evident that you don't understand chemistry and how how chemical reactions are affected by current [and vice versa].
                                    If you did you would understand how caps [and batteries] work.
                                    - Dr Seuss
                                      So, --> according to you...
                                      If you 'float' that combined DSL + POTS line's signals on 200vdc , which you filter out with a cap before the device , the signal won't pass to the device.
                                      Don't work like that,,, yet that's what you keep saying..
                                      - Dr Seuss
                                        No, it's not..
                                        Heh. Can you charge a car battery with AC ?
                                        Didn't say that.
                                        No, that is what YOU keep _reading_ and _thinking_.
                                          Invalid comment.
                                          There is no charging taking place in this discussion about a cap.
                                          If you have a fully charged battery [as with the cap] and you apply AC to it's terminals, what happens?
                                          - That discussion would valid.
                                          - And its a very good analogy of how Ripple damages the oxide layer in caps with DC present.
                                          Didn't say that.
                                          Yes you did. - MANY times.
                                          Problem is you don't understand it [electricity & chemistry] well enough to realize that is what you are saying.
                                          - Dr Seuss
