Ok, I'm going to be recapping a Biostar M7VKQ board. I've found reasonably close dimensions for all the caps, except 1.
The caps are:
5 - 3300 μF - 6.3V 10mm X 25mm x 5mm Ost RLX
3 - 2200 μF - 16V 10mm X 24mm X 5mm Ost RLP
5 - 1000 μF - 10V 8mm X 14mm X 3.5mm Ost RLG
6 - 100 μF - 16V 6mm X 6mm 2.5mm Ost RSM
12 - 22 μF - 25V 5mm X 8mm X 2mm Ost RMH
The 3 2200 μF RLP are 10mm and the 3 of them are right in a row touching each other. So I can't really go for cans with a larger diamater.
The closest capacitance I can find is a 1500 μF Panasonic FC. Specifically:
http://search.digikey.com/scripts/Dk...5-ND&x=18&y=18
Is this going to be close enough to try it, or should I just leave these 3 in? They don't appear to be damaged (though I know that doesn't prove anything).
I suppose I could try and solder in the outer 2 at an angle to fit them in, but that seems kind of risky.
The caps are:
