Can i combined 6.3v 1200uf with a 6.3v 1000uf to get 6.3v 2200uf
combine capacitors
Re: combine capacitors
Make sure that both units are the same manufacturer, series, capacitance, voltage and size. Two 1200uF units will equal 2400uF, which is slightly better.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
>the esr will be different.
will be lower than each cap separate.
then again, it can be higher than esr of original cap, depending on the quality/mfr of original and of these 2 replacements...
but 2 good quality caps will bring esr down in comparison to just one of same series...
