Hi everyone, I bought an adapter that should be used to connect a classic atx power supply on various hp sff pc types 6300 or 800g1, my doubt is the 6-pin P2 connector of the original hp power supply has connected the cables 1 2 3 4 while 5 and 6 are empty that instead of the adapter relative to p2 has connected 2 3 4 5 while 1 and 6 are empty, I don't know if it works because I can't find pins who can help me? Thanks anticipate.
Psu pc Hp sff
Re: Psu pc Hp sff
I've worked on two of those HP SFFs, 6300's IIRC. One had a junk "replacepower" replacement, whose original caps failed after 6 months or so.
The second had its original PS, but with tired/bulging caps. So I found an OEM PS for the first computer.
Then, each one ended up with recapped OEM PSUs.
Try to find pinouts of the OEM connectors, and see if any pins are redundant.
Be especially certain that no pins/voltages are transposed to the wrong places, as this will (probably?) destroy the MB!"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
Re: Psu pc Hp sff
I've seen dell SFF's with an atx wire moved from one place to another so SFF PSU would not turn on
I moved to where it would be under ATX and it workedCap Datasheet Depot: http://www.paullinebarger.net/DS/
