ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
    Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
    So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped out the two smaller electrolytics with the following:
    Old Parts: Chang CD110 47uf 50v, Chang 4.7uf 50v.
    Replacements: Ymin LKM 39uf 50v, Topazcon LJ 4.7uf 50v.
    Now, whether these new caps will be better than the old ones remains to be seen, but it will be interesting to see how they might age.
    Now onto the secondary, I swapped out the SBL3040PT rectifier on the 5VSB rail with a SB560, i also tested the SBL3040PT and found that indeed, one half of it was shorted.
    I added the missing PI coils on the 5v and 12v rails, as well as swapped out most of the secondary caps with the following:
    5VSB - 2x Cheng LOWESR 470uf 16v ⇒ 2x Topazcon LF 1000uf 10v.
    12v - Cheng LOWESR 1500uf 25v ⇒ Ymin LKM 2700uf 16v + Capxon GF 1500uf 16v.
    5v - Cheng LOWESR 2200uf 10v ⇒ Ymin LKM 2700uf 16v + Topazcon LF 1200uf 16v.
    3.3v - Cheng LOWESR 470uf 10v ⇒ Chengx GR 2200uf 16v.
    -12v - Cheng LOWESR 470uf 16v ⇒ Ymin LKM 680uf 25v.
    So now that was done, it was time to test the PSU, so i got it all back together, plugged it in, and... Nothing.
    Well that's not fully true, the 5VSB did come on, but everything else was still dark, but the main fan did twitch, which suggests that the main PSU did try to come on, but something was stopping it. So now it was time to troubleshoot, and my first though on what to check was the secondary capacitors. So i first try removing the 2700uf cap on the 12v rail, and that did nothing, so i try the same thing with the 2700uf cap on the 5v rail, and bingo, the power supply came to life. And it would still come on even after putting the 12v rail capacitor back in place. So after a bit of poking around and swapping the 5v rail capacitors around until i decided to go with a Chengx GR 2200uf 16v + Capxon GF 1500uf 16v caps for the 5v rail, since the PSU would still start with these in place.
    So now the power supply is "repaired", the next part of this adventure will be throwing together the rig that this thing will run, and then counting how many days this thing runs before either the switching, or the smoothing part of the PSU gives out, but that will (hopefully) be tomorrow.
    I'm not a expert, I'm just doing my best.
    Re: ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
    How are those Ymin caps holding up in general ?
      I've been swapping Ymin LKM caps into a lot of equipment, they seem like a really good value on paper and should theoretically be very reliable. Curious on how they are performing as well.
        Zumax=The only variant I remember seeing with that brand, is feloniously bad!
        Possibly much worse than Apevia!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        16 GB AData XPG Spectrix D41
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          I haven't had a chance to start the tests, mostly because the rig i was going to toss this PSU in to would not boot to OS (it would boot to BIOS), so i put this on the back burner. But i might be coming back to it soon as i recently had some success with a pair of new PCs I built, which gives me confidence in finally getting the rig i was throwing together (mostly out of parts pulled from rigs i found in the trash) working.
          Speaking of Apevia, when i was looking for power supplies for the rigs i built recently, i nearly considered getting this thing, as the top review mentions it being OEMed by Andyson, but ended up deciding against it, as there was a discrepancy the model number in the review and the listing model number (I wouldn't be surprised if they changed OEMs for a much cheaper one, but kept the old listing).
