Lenovo T490s
    Lenovo T490s
    i got a t490s someone tried to work already on it when i opened i saw there are some missing pads and the resistors are moved from the actual position
    can someone please upload the picture so that i can compare what is missing and also the right direction to connect the resistors as i dont have the board view
    also will appreciate if someone has the board view or same area picture
    and system is not switching on can someone guide me please
    Re: mec 16xx dump with info block
    @myjunaid
    At first glance everything looked fine to me in the picture, after checking the boardview file I was able to see what you meant in your post.
    Search and you will find.
      Originally posted by myjunaid
      Thank you very much for your time and effort i will update you the outcome
      Originally posted by AAAC View Post
      @myjunaid
      Thanks for your time and i will update you the outcome
