Mackie CR4 monitors
  • UserXP
    • Apr 2012
    • 322
    • Serbia
    Mackie CR4 monitors
    Hi, everyone.
    I have recently bought these Mackie CR4 monitors to replace my old PC speakers which were at their end. I am blown away by the sound that these monitors produce and I really like their looks. I would like to ask a few questions I couldn't find a direct answer to on the internet.
    I noticed that the active speaker is quite warm even when the speakers are off. As a test, I flipped the mains switch at the back of the powered speaker to OFF position to see if it would cool down. It did, but after a whole day, as if there is some sort of insulation inside that keeps the warmth in.
    Also, I would like to ask if anyone has had the opportunity to see the inners of these speakers.
    1) Is it normal for them to be warm all the time, even when not in use?
    2) Will that cause damage to the capacitors or other electronics inside?
    3) What type of capacitors are inside (in reference to brand/quality/rating)?
    These are just informational queries by me, as I would like to know how to best keep them safe and last long. I really had to save money for quite some time in order to be able to buy them, and I would like to take good care of them now.
    Thanks in advance.
  • UserXP
    • Apr 2012
    • 322
    • Serbia
    Re: Mackie CR4 monitors
    If it would be of some assistance, here is the picture of the speakers/monitors. My version is for the European electric appliances standard, so its rated at 220-240V, 50Hz.
    • Chungalin
      • Jul 2014
      • 422
      • Spain
      It doesn’t care if "not in use". As long as the power switch is ON, the unit is consuming almost the same as if there’s sound. Well, it’ll consume more when loud, but below a certain volume it’s the same. Surely it uses a toroidal transformer to produce ±24V. Of course it’s adviced to turn them OFF overnight, like any other electrical device.
      • UserXP
        • Apr 2012
        • 322
        • Serbia
        Hi, Chungalin, thanks for that input. The speakers are not used to produce a very loud output (well, for the majority of time), mostly it is in the range of "normal" volume. Is that torodial transformer prone to making the heat? I might guess that there is some kind of heatsink inside the active speaker, the heat is generated somewhere bellow the bass port (I suppose the heat escapes through the port opening, at least to some degree).
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          I've edited your image. See the area enclosed by the yellow rectangle?
          Those two screws hold either the E-I transformer, or heatsink for the amp IC/module. Probably the transformer, which will remain warm anytime AC power is connected or switched on.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • UserXP
            • Apr 2012
            • 322
            • Serbia
            Hi, thanks! That is exactly where most of the heat can be felt when touched. It is warm, but actually more towards hot. The previous poster mentioned that they are actually ON all the time. I read the original Owner's Manual twice and there is only one suggestion mentioned, instructing the user not to use the speakers near the heat source appliances. It also says that ambient temperature should not excede 40°C, although it is 22-24°C inside the room. I just want to keep them healthy and operational for the time to come, so that is the main purpose of this topic. Simple suggestions about how to keep their electronics in good shape through daily usage.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Even with that switch off?
              If so, it's likely a standby switch, not a traditional AC power switch...
              Throw that switch to "soft-off" and measure across the power cord with an ohmmeter- bet there's continuity.
              Sometimes, the transformer in "220-240V" equipment is actually optimised for 230V nominal. If your line voltage is closer to 240V, the transformer core will be running higher up on its B-H curve, increasing losses/heating. It's also possible the transformer was deliberately designed in this way to provide a stiffer supply for the amp, and when the capacitor-input filter draws peaks of current on each half-cycle. Which would be the cheaper way; the old 70's-80's stereo equipment regulated well also, but those transformers were huge. Which, of course, isn't practical in computer-speaker-sized systems.
              In smaller, higher percent-impedance transformers, it's worse with no load. Without the I*R drop, which the primary experiences under load, the effective voltage the primary "sees" is closer to actual line voltage; the core losses are higher at no-load than when supplying full current. Of course, with the amp at full power, overall losses are greater while transformer core loss is less.
              Best would be to either unplug or use a line-switch (on receptacle or elsewhere) to drop AC power when not in use, if you wanna keep the amp/caps/etc cool when you're not using it.
              EOL it...
              • UserXP
                • Apr 2012
                • 322
                • Serbia
                Hi, Kaboom, thanks for the detailed explanation. I don't have any measuring equipment, but I could ask a relative of mine who I think does. So, if I understood your post even remotely accurate, the heat is generated by the AC line transformer, regardless od its type.
                Our mains power is ~220V, rarely does it go past that.
                The active speaker have one Power/Volume switch on the front, but I think it is exactly as you say - a stadnby power switch. Another switch is on the back of the speaker (it is visible in the picture). It is probably the main switch. Anyway, here is what I observed:
                - When back switch ON, standby switch OFF, the speaker gets hot.
                - When back switch ON, standby switch ON, the speaker gets hot (almost identical temperature to the touch).
                - When back switch OFF, the speaker cools down after a while.
                Does this help a bit in determining the heat effect? If it does contain the capacitor-input filter, is that cap in danger of overheating? I know, his is kind of a retorical question as all caps suffer from heat, but is it designed to cope with the implementations you wrote about? Whatis the life expectancy if it is always ON in that standby mode and hot?
                I ask this because it is not practical to go around and flip the back switch on and off all the time. I suppose this is why they provided the front switch as well. In your experince, when manufacturers choose this type of solution, have they thought about its safety and durability?
                • UserXP
                  • Apr 2012
                  • 322
                  • Serbia
                  Hi folks.
                  Sorry for resurecting this old thread.
                  I have recently noticed an intermittent crackling noise coming from the monitors. Its sound colume is irrelevant to the position of the volume knob. So as long as the monitors are in the On state, tjis popping/crackling is heard. So, it makes no difference whether I turn the colume knob all to the lowerst ot highest. What could it be?
                  • UserXP
                    • Apr 2012
                    • 322
                    • Serbia
                    As a follow up, I tried with a new audio cable, I cleaned the contacts, and I also tried plugging them into different power outlets - no difference. I also disconnected the active speaker from anything else but the power outlet, and the crackling sound is still there, so my guess is that there is nothing wrong with the sound card the speakers are connected to.
                    What is irritating the most about this issue is that the noise is completely intermittent and cannot be duplicated by the means of setting up a specific scenario. Other than that, the speakers reproduce the playback sound superbly and there's no problem with the sound or volume. It's just this hissing/poping/crackling noise that is quite irritating when listening to something.
                    The crackling sound resembles the noise you can hear when playing a mildly scratched LP record.
                    Any ideas about this issue and what kind of a malfunction it can be?
                    Thanks in advance.
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      suspect bad transistor
                        Did you open it up and inspect it yet? May bad semiconductor or may be bad brown conductive glues.
                        Open it up and upload good clear pictures.
                        Do you still hear the crackling sound if the Volume is turned all the way down? That will tell you if the problem is before or after the Volume control, see the audio signal path in the manual:
                        • UserXP
                          • Apr 2012
                          • 322
                          • Serbia
                          Hi, and thanks for the input.
                          I did open the active speaker a few days ago, but I didn't take any pictures then. I will do it tomorrow. But, I inspected it then, nothing seemed odd. All the caps looked fine, they are some Cap-Top brand. The board does feature some black gunk in specific areas, although it didn't look like it was burned, melted or something like that, it looked like a nice hardened layer of that black stuff, whatever it is.
                          Yes, the crackling sound seems to be separated from the audio. It doesn't matter whether the volume knob is all the way down or up, the crackling sound is of the same strength/volume and is equally heard on both speakers (active and passive). Even with no cables attached other than the power cable, the noise is heard. I guess that eliminates bad audio cables or bad source. If I play some audio, it plays normally and responds to the volume knob without any distortion.
                          I have disconnected and unplugged the speakers since the problem occurred, as I was scared not to cause any additional damage to their electronics.
                          Do any of these pieces of information help in "making a suspect"?
                          Here are some images of the Mackie CR4 PCB on this link:
                          http://velociraptech.blogspot.com/20...sassembly.html
                          I will make some images of my own, but the images on the link might be usefull to you as a reference to the board layout for now.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            both speakers crackling suggests power supply or input source if input is connected .
                            • UserXP
                              • Apr 2012
                              • 322
                              • Serbia
                              If you mean the audio input, then we can cross that one out. The crackling noise occurs when the active speaker is connected to the mains and switched on. No other inputs, except for the power input. :-)
                              • UserXP
                                • Apr 2012
                                • 322
                                • Serbia
                                Ok, here are some images. I couldn't get a clear approach from the top of the board because everything is so tight in there.
                                Hopefully, you will be able to spot the area of suspect. :-)
                                • UserXP
                                  • Apr 2012
                                  • 322
                                  • Serbia
                                  Guys, here is some new development. This afternoon I took the time and removed the power supply as it was blocking the view over the board. To my horror, I found a completely corroded and snapped diode (image). One of its leads was completely turned into corroded powder. I can't really make out the markings on what has left of it, but it looks like "41". The diode was mounted in the now empty space on the board. The board is slightly blackened in that area, that power supply must be producing a lot of heat. All the caps visually look normal. There is still some corrosion left beside the black rectangular box that you can see in the image (it's the left/right speaker position select switch), but it's very inaccessible to clean. I cleaned everything I could (image), but I will try to completely remove all the remnants of that corrosive gunk.
                                  If you look at the attachment (20190704_172813.jpg) from my previous post, the problematic diode was soldered where the R77 marking is (right side of the image, lower mid). The R77 resistor lies exactly "between" the diode solder contacts.
                                  Can this little diode be the cause of the intermittent noise, because everything else was working properly on the speakers?
                                  If you have any idea what exactly type of a diode it is, please let me know so I can replace it and see if there is any change. I guess the other two diodes in the vicinity are identical, but I can't make out the markings on them.
                                  • Khron
                                    • Sep 2006
                                    • 1350
                                    • Finland
                                    That's pretty consistent with the photos from the link you listed a couple posts above.
                                    That zener diode and its pair (Z4), along with those two fatter resistors, burn off perhaps a bit too much power, to make the +/-15v(ish) to power the opamps, from the main power rails for the amp chip.
                                    In an ideal case, you'd wanna remove those two resistors and the remaining Z4, and power the line-level circuitry from a (dual) bench power supply, noting the current draw, and then recalculate the resistors and beef up the zeners (ie. their power rating; those glass ones are 0.5W tops).
                                    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                                    • UserXP
                                      • Apr 2012
                                      • 322
                                      • Serbia
                                      Hi, Khron. Thanks for the input. I am not sure I can follow the ideal scenario as I am not sure how to exactly do what you suggested (sorry for my lack of knowledge ). I will test the diodes and resistors with the multimeter tomorrow as it is kind of late now. If they turn out to read fine, could we try with replacing the diode for now and see where it will get us? But, if the method you suggested is the only way to calculate the voltage and power of the diode, then I shall have to ask for detailed instructions on how to perform the procedure.
                                      Unfortunately, Mackie doesn't provide service manual for this specific model. Also, there seem to be additional components under the black boxy blob. I can't see the printed markings on the board for the blown diode, let alone potentially other hidden components.
                                      I really like these monitors and the sound they produce, but their lifespan seems to be quite short.
                                      Many thanks in advance for further assistance.
                                        Bad brown corrosive and conductive glue strikes again.
                                        • Flaku_34
                                          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                          by Flaku_34
                                          Introduction:
                                          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                          04-18-2024, 12:47 PM
                                        • madan1
                                          Mackie Th15 SMPS low Vout
                                          by madan1
                                          I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                                          It is basically a smps with amp and some dsp.
                                          The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                                          Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                                          By the way, the ferrite core of L10 is broken,...
                                          02-16-2025, 04:15 PM
                                        • BigOof
                                          Pioneer RM-07 Active monitors cutting out from time to time
                                          by BigOof
                                          I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
                                          12-18-2024, 04:35 AM
                                        • jolivares
                                          Black tape in the mainboard inside apple's devices
                                          by jolivares
                                          Hi everybody.
                                          i'm looking for the black tape inside apple's devices.
                                          Is the tape tha covers the shield on the mainboard. when you take it out, loses the adhesive.
                                          It is very thin.
                                          can somenone help me to find it for a better repair?
                                          Thanks, God bless you.
                                          09-09-2024, 08:07 AM
                                        • PedroGG90
                                          How to bypass hp pavilion laptop booting only if battery is inside ?
                                          by PedroGG90
                                          Hi everybody .
                                          I have a hp pavilion dv 9500 ef laptop that i think is designed to boot only if battery is inside , and my battery is dead .
                                          Any way to bypass it and make it work from power brick only without the need of a battery ?...
                                          02-15-2024, 08:19 AM
