Philips 47PFL7403D/10
    Hi there to all!!
    New to forum, first post but watching it several months silenlty.
    I need your advice:
    power supplyQ PLHC-T801A (UD)
    No response while connected to wall plug.
    I figured out that R5 is burnt. I have changed it with a new one and now when plugged in a relay is clicking all the time.
    No led blinking.
    After a minute the R5 is broke down again and everything dead.
    All caps esr measured and they are very good.
    Any advice for this issues?
    Is it truly the problem from the PSU or maybe the mainboard?
    Thanks a lot
    Nodas
    Re: Philips 47PFL7403D/10
    You need to change u101. It is a 7 leg ic chip that is through hole soldered in.
    Put a new 120 ohm resistor in r5 and put the correct fuse back in around that r5. Also, check the solder connections under the power board, the ones under the transformers tend to burn and start on fire. Touch up all the through hole componnets with fresh solder.
      opps, wrong power supply
        Post some pics of the power board. Take one of u101, you may see a hole in the side of it, or a blown off leg.
          Timmy thank you very much for your response and help.
          I have changed already:
          > U101
          > D101A,D101B,D101C,D101D
          > PC201,PC101,PC102
          The result was that relay clicking and after a little the R5 burnt again. The fuse I have changed once did not blow again.
          The solder joins are in very good condition.
          Also I have tested D106A and it seems open. the diode writes T2d 83 on it.
          do you jnow anything about this?
            What is the mark on top of the 8 pin IC. Picture too small to read component names.
              Check zd 101 and zd 103 on the back of the power supply
                Oh man!!
                You are tottaly right!
                After the replacement U101 is broke down again. The spot show that ic is fried.
                  Zd101 tested with multimeter seems fine but
                  Zd103 shows the same value both sides with multimeter but I see that it is in parallel with an smd capacitor.
                  Do I have to desolder it to check it again?
                  Should I check with external voltage?
                  Do you know the value of the zener diode?
                    Originally posted by vazaki View Post
                    Oh man!!
                    That's the beauty of posting photo's.
                      zd101 tested with multimeter seems fine but
                      zd103 shows the same value both sides with multimeter but i see that it is in parallel with an smd capacitor.
                      Do i have to desolder it to check it again?
                      Should i check with external voltage?
                      zd101 5.6
                      zd103 18
                        Thank you very much!!
                        I desolder U101 and measured again ZD101 & ZD103 with multimeter and they seem fine. Do I have to desolder them and check them again?
                          No its fine
                            Any other suggestions?
                              What is the part # of U101
                                if you want to be helped, you can post very clear pictures of te board or even the faulty portion, both sides, with traces well distinguishable, and put marks on them to show parts changed and parts found blown.. one can have no wants to find and download schematic..
                                  U101 is FSQ510. Lots of them on ebay.
                                    So it looks like output of U101 bad. What is causing failure? Transformer shorted?
                                    https://cdn.badcaps-static.com/pdfs/...f3dad871c4.pdf
                                      Here are the photos!
                                      The parts that have been replaced:
                                      > R5
                                      > D101A
                                      > D101B
                                      > D101C
                                      > D101D
                                      > PC101, 102, 201
                                      Also I need your help about T2D 83 diode. I measure it with the classic way but it seems open. Is it a special type of diode?
                                        R5 does not look good. Best that you check its resistance.
