Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting & Designing Networks
Old 12-11-2017, 09:05 PM   #1
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default TP-Link TL-SG1008 Gigabit Switch - pre-emptive recap and fan upgrade
I have a TP-Link TL-SG1008 I bought some time ago, second hand. I never used it because the fan was horribly noisy and I didn't need more than 100Mbit anyway.
Now, I find myself needing the bandwidth. So I decided to look into the situation...
I did a pre-emptive recap of all the crapcaps (may have been unnecessary, the thing runs really cool anyway) but hey, why not?
I also replaced the original, noisy and worn, single fan with two new ones. Each of the new ones use half the power of the old, and make a fairly soft noise in comparison to the screech of the original fan.
After putting it into service, I then discovered how trashy on-board Realtek chips are... and had to upgrade to some decent Intel PCI-E cards.
-David VanHorn
Agent24 is offline   Reply With Quote
Old 01-10-2018, 11:39 PM   #2
tibimakai
City & State: Los Angeles/San Dimas, CA
Line Voltage: 120VAC 60Hz
Default Re: TP-Link TL-SG1008 Gigabit Switch - pre-emptive recap and fan upgrade
I did this, to a TL-GS1008PE. I'm using it, with security cameras. I will need to pick up another one, or upgrade to a 16 port one(POE version).
tibimakai is offline   Reply With Quote
Old 01-19-2019, 02:07 PM   #3
Curious.George
Make sure you do your homework wrt the PD's and PSE's before you get too heavily into POE. It seems like there are a variety of (incompatible) approaches to that problem (from all varieties of vendors!)
You're also likely to find that many POE switches have their (PSE) power supplies sized for "telephone loads" -- i.e., 7W/port. And, may not be able to support ALL of the ports on the switch, simultaneously (so you may end up needing a bigger switch than you originally expected)
Note, also, that some switches allow you to augment the internal power supply.
Curious.George is offline   Reply With Quote
