asus ux510uw wi-fi disabled by hardware
    I I bought an Asus zenbook ux510uwk motherboard, all works fine except the wi-fi,
    there is a red X . (is very frustrating resend it to china)
    I have tried:
    1 - I don't see any wi-fi enable button, all fn+button works (light, etc)
    2 - two different windows 10 version
    3 - no driver issue
    4 - 3 different wi-fi adapter
    5 - on bios, wi-fi is unlock
    6 - bios dump
    7 - fn+f2 (all network disabled) works
    If I use automatic throubleshoot -> wi-fi is disabled by hardware
    Any suggest
    Re: asus ux510uw wi-fi disabled by hardware
    Are you sure its not a driver issue .Any problems in device manager
    UX510UW ATK,ASUS Wireless Radio Control,Qualcomm or intel wifi driver,Intel Serial IO I2C Driver
    Intel Serial IO GPIO Driver (for UX510UWK)
    Intel Wireless Lan Driver (for UX510UWK)
      If everything else is OK,last chance is something like that
      https://thecomputerperson.wordpress....-pin-20-trick/
      https://lybomudr.ru/en/132-zapuskaem...drugikh-2.html
        Thanks, I'm reading the links
        I forgot, bluetooth works well (same card)
          Just to consider all option, the pic show the three card I tried. The intel 7265 is the card I supposed original.
            8260NGW and AC7265 are the original intel cards. Does LAN work ok,are you getting a MAC address.
            EDIT: The UW model has an AC7265 and the UWK has the 8260NGW .
              Originally posted by gabiz_ro View Post
              Thanks,thats good info .
                Send it to China is a nightmare but let's consider the situation on the side of a end user, he buys a card declared as new, mounts the card correctly, installs windows 10 (two version), installs all drivers from the asus site ...
                If the card works correctly (I must say that the serial number is not present in the bios and I think it should be present) there should be no problems, is it correct?
                  Can you post your bios backup.The UW and UWK have 2 different bios. Does the boards silkscreen part number match with any part numbers on the stickers . Did you check LAN MAC address.
                    Actual bios is from DrBXXXX
                    ZenBook UX510UWK-F1_bios-version-300
                    this bios has a different layout respect bios for ux510uw (not lock_unlock button for wireless)
                    In the pics other details
                      The LAN is missing in your pic on device manager. Do you have the MAC address on a sticker on the ram slot. I could try adding the mac to the bios manually but its easier to use asus bt2.exe tool .After adding a mac and getting an ip address through the lan ,the wifi may start working.
                      EDIT: i`ll post a bios to try. bios moved to - https://www.badcaps.net/forum/showthread.php?p=966610
                      EDIT: Added bt tool, zip password in pm .
                        BT2.exe seems don't work , no change mac , no serial
                        I'm trying your bios
                        thanks
                          With HEX editor I found the MAC location (2301C2h) on the old UX510UW bios, if the location is the same, I can put the same MAC on UX510UWK bios. Unfortunally the chinese guy has remove all labels on board so I don't have the original mac.
                            Last news,
                            I followed the instructions of the link, posted by @gabiz_ro,
                            and indeed wi-fi is on.
                            At this point I don't know whether to deliver it to the owner with this change. I also bought the original wi-fi card, Tuesday should arrive.
                              Good news,
                              I learned something else, this notebook accept only intel 8260 wifi card, otherwise it is necessary to cover two pins to enable wi-fi and BT.
                                thanx alot
                                  Hi, thanks for sharing but I download bt.exe zip but I need password, can you send me in pm please, thanks.
                                    you can find bt.exe/bt2.exe here https://novoselovvlad.ru/2019/03/07/...transmit-tool/
