DAG3JBMB8D0 HP 3 times blink
    I have hp gaming board DAG3JBMB8D0 the problem is when i press power button dc jack light blinks 3 times white. It has bq738 charging ic i found acdet 2.1v after changing resistor the voltage is 2.8v but same problem. Acok is 3.2v and the board has 3v and 5v.
    Re: DAG3JBMB8D0 HP 3 times blink
    AD_ID voltage??
      Where to check ad id can't find schematic of this model on dc jack i have 19v, brown pin has 0.50 v, and yellow and white pin have 5 v each. Please help how to trace this problem.
        AD_ID is brwon pin. Its likely ok at 0.5V but cant be confirmed without schematic.
          It means low power adapter, check your charging ic requirement.
          Ac_ok is going to sio and ad_id should be 0.6v, check if your charging port is fine and not broken too.
            @Udemzy, do you have schematic of this board?? How you concluded AD_ID should be 0.6V??
