acer 5742g power on 1secand
    hi
    I have acer acer 5742g power on 1secand
    When you press the power button, it draws about 40 mA
    3v is OK
    5v is OK
    run power 3v 5v .1v is OK
    slp s3 slp s4 slp s5 rsmrst is OK
    bios is flash
    no short
    change cpu
    NOT. After I removed the main BIOS chip and tested the device, it worked without data
    Re: acer 5742g power on 1secand
    What is the mb code?? Check 3V/5V/1.5V dc-dc transfer(From ALW to VS) happening or not.
      yes is ok
        LA-5893P Rev:0.1
          Impedance of all coils and voltage on all coils.
          Once it powers on, check where the voltage stops on each coils
            acer 5742g no power
            I have acer 5742g no power
            the power button 18v
            where is the problem
              Start with checking the voltages on mosfets PQ51 & PQ52.
              See attached.
                18 v
                  Post the voltages on each pin and each mosfet.
                  Source pins will be 1-2-3 ; pick one
                  Gate pin will be 4
                  Drain pins will be 5-6-7-8 ; pick one
                    If you have 18V at switch, check 51ON# circuit.
                      source pin is 19v gate 8v drain 19v
                        Same readings for both mosfets?
                        Remove all power. Meter in resistance mode
                        Check the resistance of each of these mosfets:
                        Source and drain
                        Source and gate
                        Gate and drain
                          ec_on 0v
                            Originally posted by ddhlawi View Post
                            ec_on 0v
                            flash clean and tested bios and check sio requirements
