Vizio E321VL
    Re: Vizio E321VL
    Originally posted by killian6pk View Post
    Well you can officially put me into the dumber than a rock catagory. It was in backwards. Took it out and resoldered it and now I am getting 171.9 volts at the Filter Cap. However I am not able to get the voltage to increase by pushing the on/off button. So I guess now I should check for 5V, 12V and 24V at the cable to the Main Board?
    The cap is probably ruined by that, I'm very surprised it didn't vent or blow the fuse.
      Re: Vizio E321VL
      So I need to pull it and check ESR and capacitance or just replace it?
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
        Re: Vizio E321VL
        Decided to check the Vizio light on the front. It is steady Orange where I had no light before. Must be some progress. However, there are no backlights or nothing changes when I push the power button. At this time all the boards are connected to each other.
          Re: Vizio E321VL
          Ok Now you have the DC standby voltage of 170Vdc, since when you turn the power switch of the TV and the voltage did not go up to 400Vdc, it can mean two things: It is not getting the PS_ON from the Main board or the PFC IC circuits are not working. I will need you to get the P/N of the PFC IC and the SMPS IC so we check the VCC pins.
            Re: Vizio E321VL
            @TOM, the cap should be OK, since the Didoe is put in backward, the diode never conducts. You can see the diagram I made.
            Killian, you may want to recheck all the parts you have installed, just to be sure.
              Re: Vizio E321VL
              Picture of that D100 as mounted will help also.
              Bud check post #40 and the third page for Tom66 reply on Filter Cap etc.
                Re: Vizio E321VL
                Ok the part # for the PF IC is LTA100 over PQU18 (could not find a datasheet under either number. I will check DigiKey and Mouser to see if I get a hit on either number.
                Part # for SMPS IC is: L6599AD
                Data Sheet is: https://cdn.badcaps-static.com/pdfs/...d758189067.pdf
                  Re: Vizio E321VL
                  The Cap is fine, if you look at the diagram, when you put in that Diode backward, the diode was never turn on, it was in reverse bias mode. you are OK, no need to change that cap.
                    Re: Vizio E321VL
                    if we are now looking for smaller errors Killian6pk You did say you had resoldered some traces - I have been looking but could only see what I thought was one and it looked ok but of you want us to check you will have to mark where to look.
                    Anyway whilst looking I did find what appeared to be two broken traces. it may be the picture or shadow but please can you check where marked in attached.
                      Re: Vizio E321VL
                      I need closed up pictures of the bottom side of the board acround the pfc ic and the SMPS IC so I can trace out the connections, also need the cloased up pictures of the connector on the power supply board so i can see the lables on them, I need to find ot which pin is PS_ON pin, this will be the next step.
                        Re: Vizio E321VL
                        Again, SELLDOOR with his GREAT eyesights and software! Killian needs to really re-check his works really well.
                          Re: Vizio E321VL
                          If you keep the board oriented in the direction of the picture and look at C608 in the upper left of the board. Go to Buds redline of the picture and look above the number 4 that he placed on the picture. The second location is on the far middle right of the board next to a large black arrow at D331 also look at the scratch across the black arrow to see if that could be a problem. Copper is showing thru.
                            Re: Vizio E321VL
                            Ok I will work on those for you. Back in a few minutes.
                              Re: Vizio E321VL
                              Attached are the pictures you wanted. Kind of gloomy outside today so I hope this is clear enough.
                              On the Inverter Connector picture Pin one is at the top.
                              On the Main Board Connector Pin one is at the bottom.
                                Re: Vizio E321VL
                                OK, I will look at the pictures tonight, I cannot find any info on that PFC IC P/N L100 either, it may be difficuit to figure out the VCC pin of that IC, will see after I look at the pictures.
                                OK, picture#3 post 54, CN101 Pin 11 is PS_ON PIN, please check the voltage onthat pin, it should be around 3VDC or higher when TV is switched on.
                                  Re: Vizio E321VL
                                  The repairs look ok and the scratch is not a problem. Its getting late here now, Im off to bed. If you get a chance check out the trace damage if there is any, by doing an ohms test between joints along the trace.
                                    Re: Vizio E321VL
                                    It is 0.0V using common to ground pin on that connector and also to the ground screw by the AC Input.
                                      Re: Vizio E321VL
                                      OK, you do not have the PS_ON signal from the main baord when you trun on the TV, that is why the PFC and the 12/24 Vdc power supply do not turn on. So we need to find out where the fault is on the main board.
                                        Re: Vizio E321VL
                                        You may want to read this thread also:
                                        https://www.badcaps.net/forum/showth...t=19666&page=3
                                          Re: Vizio E321VL
                                          Maybe re check pson test as in
                                          https://www.badcaps.net/forum/showpo...2&postcount=26
