RCUnlocker
    Re: RCUnlocker
    post your locked bin
      Re: RCUnlocker
      I have Elitebook 850 G6 with 32 MB chip read , but the unlocker says Wrong Chip.
      Is it supposed the password to be stored here on this W25Q256JVEN or on another chip?
      Please can somebody help me ?
        Re: RCUnlocker
        Seems the readout was not done properly without desoldering the chip, anyway I would like to know how to proceed with 32MB when I desolder and read it ...
          Re: RCUnlocker
          So if it says wrong chip, try another chip. 16MB is the one you need.
          But it's always good to make backup of the 32MB chip just in case.
            Re: RCUnlocker
            I don't find any other relevant chip, maybe I am blind, or it is located on the other side of the board?
            I desoldered the chip now and the contents of the readout is exactly the same like attached
              Re: RCUnlocker
              This is the 16 MB chip winbond on the other side of the board
              Unlocked this one with your unlocker, but only the Fingerprint is gone, but still asks for administrator password?
                Re: RCUnlocker
                Your 32MB file seems broken to me. I am not sure why your password was not removed but maybe you are still having issues with your programmer.
                  Re: RCUnlocker
                  Interesting fact that I see here is that my backup is totally encrypted and I couldn't find anything inside written HP Elitebook, or the serial number of the laptop - which otherwise I am finding on many backups that others posted here and on other forums. Maybe it had the latest version of BIOS which is now totally encrypted? I am surprised...
                    Re: RCUnlocker
                    Bought somewhere the service and he has sent me a patch from my backup and also some infos to fill after flashing that patch. If it can be useful for developing a solution I upload here that patch, but the infos he gave me the serial of the laptop he has found exact serial , as I said I was not able to decipher my serial as it seems to be encrypted?
                      Re: RCUnlocker
                      Thank you very much for this great tool !
                        Re: RCUnlocker
                        Hi All, I've taken a copy of the 16mb and 32mb chips, run the 16 through the rc tool and flashed back but am getting the flashing caps lock issue that others seem to be having. I've attached both bins for reference. Anything else I can try myself? Many thanks in advance!
                          Re: RCUnlocker
                          Sorry forgot to add this if for a HP 840 G7
                            Re: RCUnlocker
                            how to view the info for a 32mb bios bin? like the one I attached..
                              Re: RCUnlocker
                              Need clear password bios hp x3660 1040 g6
                              bios 32mb
                              ec 16mb
                                Re: RCUnlocker
                                bios 32mb
                                ec 16mb
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Re: RCUnlocker
                                  Hello friends I would like to know how to dump the bios without desoldering winbond 25Q256jvEQ
                                  Sorry for my English I use Google translation
                                  HP EliteBook 840 G5 Notebook PC
                                    Re: RCUnlocker
                                    worked fine with hp 840 g6 . just drag the 16mb not the 32mb
                                    thank you for thin great software
                                      Re: RCUnlocker
                                      Hello brother, i tried HpUnlocker, the old version for Hp elitebook x360 1030 G3 but it didnt work, can you help me, do this Rcunlocker work?
                                        Re: RCUnlocker
                                        You need to dump 25Q128JVPQ chip only. Buy hot air station and WSON8 adapter to do the job as it should be done. Or use tiny wires and solder them to the eight square contact surfaces around the chip. Again use tiny wires, because otherwise you will tear down the contact surfaces off the motherboard pretty easily.
                                          Re: RCUnlocker
                                          Why don't you just try it to find out for your self? Of course it's working.
