hp probook 470 g3 i5
    Re: HP Probook 470
    Originally posted by peste View Post
    try..
    thanks i tried this but the display stays black and the fans start spinning after about 20 seconds
      Re: hp probook 470 g3 i5
      I tried other files always taken in the forum referring to 470 g3 but in this case it doesn't even start
        what model of motherboard does the laptop have ??
          model motherboard is: DA0X63MB6H1 REV:H
            try post # 28, from here.
            https://www.badcaps.net/forum/showth...t=55868&page=2
              Thanks, I uploaded the file but the notebook won't turn on.
              The only file that makes the notebook start is the one in this thread (post 17) but at startup it reports an error message and the notebook never shuts down.
              My configuration is
              HP Probook 470 g3
              Intel i7 6500u
              AMD Radeon R7 video
              Serial:5CD5506XSY
              Product:P5R20EA#ABZ
              CT: 6EYPC03BB9L2NH
                hi i need bios hp 470 g3
                motherboard : DAX63CMB6D1 - REV D
                  Upload your Original Backup, and write your device Serial Number.
                  all donations are welcome,
                    i need help pls i need bios file for probook 470 g3 i3 6 generation DAOX63MB6H1
                      always when you make a bios request, also post the original bios of the laptop, even if it is corrupted...
                        this my bin file
                          Hi guys , I have a problem with my bios, the video does not start and after a while the fans turn to maximum, notebook HP 470 G3 , motherboard DA0X63MB6H1 REV:H.Original bios , please clean me region.Best regards
                            You must post the serial number
                            You havn`t made a good backup
                            https://www.badcaps.net/forum/showpo...40&postcount=2
                            When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                            On Windows, you can use the command "fc /b" to check if two dumps are identical.
                            Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                            Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                              Serial number 5CD6207SRH
                              Product P5R13EA#BED
                                File's corrupted or wrong chip.
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                  Thank you all for taking the time to help. Greetings to all members
                                    The Winbond chip is not correct unfortunately, it cannot be read…
                                      It's not the chip that has the problem, it's the programmer that has the problem.
                                        g3 430 g3 450 g3 470 dax63cmb6c0 rev c tested working 100%
                                          tank you
