hp probook 470 g3 i5
    i need a dump of bios for probook 470 G3
    thanks
    Re: dump bios probook 470 G3
    try this
      Hi guys,
      I've got a laptop which doesn't boot anymore.
      mainbord - dax63cmb6c0 rev c (tried one offered in other post, no luck).
      It comes on but only flashing lights, few beeps and high fan spin.
      No screen. All key presses not working.
      Got myself a programmer and can read the chip.
      Now looking for a clean dump for my laptop for use with the programmer or some genius who can fix my dump. I enclosed the dump with the problem.
        Re: hp probook 470 g3 i5
        Originally posted by bingbadaboem View Post
        Hi guys,
        plz test
          Hi mahmoodjavan,
          Thanks for the reply.
          With this bios the laptop is completely dead.
          Not a single light and cannot turn it on.
          I reloaded the original defective bios, strange thing it reacts different now, before it would beep and numlock would blink now only the light next to the powerplug will start flashing continuously.
          Any ideas or other bios to try?
            I got the same behaviour back on the old bios.
            When I verified it came back faulty so I erased chip and programmed again with old broken bios. the laptop when turned on two long beep , two short beep.
            Tried and verified above bios again, no succes.
              Test this one it should work.test and reply.
                hi bachir,
                Thanks for the bios. This one seems to do the trick.
                It does give a warning 'system is booting in manufacturing program mode... : 32'
                but I've seen this is either no problem or fixable.
                Will put laptop back together and see how far I get.
                Will post the results.
                  this message is because of missing info (sn,uuid...).i am happy it worked for you.this image should work on any same platform with no problem except the warning message.You still can avoid this mssage.
                    Got the laptop up and running smooth again
                    ran hp bcu util and collected and filled all required info.
                    Thanks for the help!
                      some help please with hp 470 g3 bios
                      hi all
                      i have 2 laptops 470 g3, one wasn't working so i took the bios from working one, after trying the working bios on non working board the laptop starts but first i get 35 to 40 seconds delay to start, i also get fan fast spin for few seconds, on my working laptop starting delay is about 6-7 seconds, when also i tried working bios on non working laptop i also was getting this message 'Soft Temporary Disable. To Enable ME, check Active Management (AMT) option in` but this message dissapeared after few f10 saves and restarting
                      is there anyone can help with this please i just need this 40 seconds delay gone and fan not to spin so fast at the start, the other working laptop does not have this issues, i am going include both bios here, if anyone can help would be grateful
                      470_G3_working is the other working laptop which i am using now for both laptops and used this to replace the underneath bios, but now on underneath laptop i get 40 seconds delay on starting, on it's board only 6 seconds delay
                      470_g3_not_working is the laptop which has bios issues and it doesn`t work
                        Re: some help please with hp 470 g3 bios
                        Originally posted by mgjini View Post
                        hi all
                        try..
                          Originally posted by peste View Post
                          try..
                          still same thing as before, i hope i am allowed to upload this youtube video
                          https://youtu.be/hzSI5FQ7wwM
                            try..
                              try..
                              hi peste
                              i think this is good is giving me manufactures mode 34.. but i think this is good because i will use mdnfit
                              many thanks for your help legend
                                HP Probook 470
                                My bios has no video can u fix
                                I find 1 bios working but product information not valid
                                da0x63mb6h1 rev h
                                nvidia gpu
                                  Re: HP Probook 470
                                  try and report
                                    Re: HP Probook 470
                                    Working thank you
                                      Re: HP Probook 470
                                      Hi, I have a problem with my bios, the video does not start and after a while the fans turn to maximum.
                                      I tried the bios posted above and the notebook starts and starts windows but never turns off and at startup it reports an error message.
                                      Can you fix my bios?
                                      HP Probook 470 g3
                                      Intel i7 6500u
                                      AMD Radeon R7 video
                                        Re: HP Probook 470
                                        HP Probook 470 g3
                                        Intel i7 6500u
                                        AMD Radeon R7 video
                                        try..
