Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools
Old 12-13-2011, 08:09 PM   #421
mockingbird
mockingbird's Avatar
Default Re: best cheap/free scores 1.1
I tried the latest DD-WRT on an Asus RT-N12B. I wasn't impressed. I switched to a very new custom release of TomatoUSB and it worked great.
__________________
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 12-13-2011, 08:20 PM   #422
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
the last router i ran ddwrt on did it well till it died... and a recap didn't save it.
granted, it was ddwrt lite
for now I have the Belkin N hooked up, DHCP off, N only. the netgear is doing all the routing since other in the house are using the internet and I can't take the system offline at the moment...
debating with myself on whether to dd-wrt the linksys or not...
__________________
(Insert witty quote here)
ratdude747 is online now   Reply With Quote
Old 12-13-2011, 10:22 PM   #423
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
i successfully dd-wrt'd the linksys... dd-wrt lite that is.
edit- so far, so good!
Old 01-16-2012, 12:26 PM   #424
ncovert
ncovert's Avatar
City & State: Pennsylvania
My Country: USA
Line Voltage: 120V 60Hz 200A
I'm a: Forum Junkie
Default Re: Your Best Dumpster Finds
Quote:
poor thing would have gotten destroyed because that thrift store loves to destroy things so people won't want them
Jeez, why would that thrift store do something like that?
Thats stupid!
ncovert is offline   Reply With Quote
Old 01-24-2012, 05:08 PM   #425
dood
Deputy dood
dood's Avatar
City & State: Berwick, PA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
Currently typing on a Dell Studio 1735 that I got for free. Hard drive and memory had been stripped. Had a note on it that the motherboard was bad, but I decided to check it out. Found that it would not detect a known good HD. I suspect that the goofy proprietary sata adaptor is bad.
So, this laptop is so beastly, it has a spot for a second hard drive (which uses a different kind of goofy SATA adaptor). I moved the drive over to there, and hey presto, a working laptop. I'm going to order a replacement primary adaptor, as well as the real secondary drive mounting kit, so that I have both.
Not a bad machine for free.... C2D 2.0ghz, Intel 965 graphics... runs Windows 7 just fine. I'll have to pick up some DDR2 to put in it, since I'm borrowing some for now just to test.
(And yes, I have the drive Scotch-taped into its spot, since Dell saw fit to use two different drive cages, as well as two different connectors...)
__________________
Ludicrous gibs!
dood is offline   Reply With Quote
Old 01-24-2012, 05:10 PM   #426
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
nice.
Spec wise, similar to a D830 minus the multiple hdd locations.
nice.
looks cool to me.
Old 01-24-2012, 05:21 PM   #427
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
My Country: USA
~Finally~, a laptop with 2x HDDs stock.
So tell me,,,, Does the BIOS let you put them in RAID 1?
__________________
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 01-24-2012, 05:23 PM   #428
dood
Deputy dood
dood's Avatar
My Country: USA
Pretty much the same specs as my d620 that I use at work, as well. You can use a second hard drive with that machine, but only with the special media bay adaptor. The Studio has a slot-load DVD drive, so no media bay.
Also, the battery is shot... I dunno if I feel like replacing it right now, though. For the most part, this machine is just going to sit on my desk and be used as a 2nd PC when I'm gaming on my primary.
Old 01-24-2012, 05:27 PM   #429
dood
Deputy dood
dood's Avatar
My Country: USA
Sadly, no. I've seen Dell laptops with RAID capability, but this one doesn't have it.
I also got an HP DV9000 for free that has two hard drive bays, but that one doesn't POST. I think it's got a dead nVidia chipset...
Old 01-24-2012, 05:39 PM   #430
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
My Country: USA
I'd love to know the model numbers of any laptops with BIOS supported RAID.
Looked for that for a while [years ago] but gave up and haven't thought about it since.
I have several old Gateway 1GHz P3 laptops that support up to 3 drives with bay swap adapters but none with system based RAID.
Old 01-24-2012, 05:58 PM   #431
mockingbird
965 is ICH8M which allows AHCI capability, but not RAID. ICH7R does both.
Old 01-24-2012, 06:16 PM   #432
dood
Deputy dood
dood's Avatar
My Country: USA
I know there's some Sony Vaios that support RAID. I'm not sure if it's 0, or 1, though. I could set up this Dell with software RAID if I wanted to, but I'm not going to...
Old 01-24-2012, 07:08 PM   #433
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
My Country: USA
When they come up with a software RAID that supports multi-boot I'll be in there...
Until then I need a BIOS supported RAID to do what I want.
Old 01-26-2012, 06:21 AM   #434
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
last week i got a 6 month old #27 deep cycle battery and a new in box 2x4 troffer out of my own dumpster.i forgot to lock it.maybe i should stop?my luck next time it will be junk tires or nuclear waste!
the battery just needed to be charged.the troffer had 1 busted bulb.
were not dumpstered but still free are 2 55" plasma tv's.
y buffer issues.already sold as soon as the boards come in.
kc8adu is offline   Reply With Quote
Old 01-26-2012, 12:14 PM   #435
Koda
Koda's Avatar
City & State: Prilep
My Country: Macedonia
Line Voltage: 220v AC
Never ever found or got anything for free Only can hope to get a lappy or an LCD TV.
__________________
Guns don't solve problems. I'll take 12
Koda is offline   Reply With Quote
Old 01-28-2012, 04:16 PM   #436
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
more scores today:
$10- logitech momo wheel. complete unit, in box, with all the goodies. works great. I twas originally $20 but it had sat so long that it was qualfied to be 50% off... it must have been hid behind a dorm fridge or something.
$6- netgear WGR614 v1. if I can, I will linux it up, if not, I'll do something cool with it.
Old 01-28-2012, 05:13 PM   #437
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
not much out there on this router... from the FCC ID of the radio module, it uses an internal mini-PCI B/G card for the wireless part...
https://apps.fcc.gov/oetcf/eas/repor...='P27-LA10'
I guess I will have to open it up and look inside when I get home...
Old 01-29-2012, 06:56 AM   #438
ncovert
ncovert's Avatar
My Country: USA
I'm a: Forum Junkie
Okay, I made some good scores about a week ago. These are from craigslist:
Dell Dimension 4700 (has bad caps, no ram or hard drive, I put in a 120Gb drive) for $20
Compaq Presario SR1710NX(no ram, bad caps, I put a different mobo in temporarily) for $15
Dell Optiplex 170L (no cpu fan or shroud, no ram, 40Gb HD) I put in 1Gb of RAM and a 80Gb SATA Hard drive and a new cpu shroud. Now delighting one of my relatives. for $5
IBM Aptiva 2176-C33 (Pentium 133Mhz, 48Mb RAM, someone upgraded to a 40Gb Hard drive that was dead) for FREE
Gateway FLEXATXSTC Bro Essential 700c (Complete system with 60Gb Maxtor HD) also for FREE
Gateway model "450" (Intel P3 450Mhz, no ram, 20Gb HD) for FREE
A really cool fan controller/USB Card reader for $10
A Western Digital 500Gb hard drive for $25
A Western Digital 320Gb hard drive for $15
2 Maxtor 120Gb hard drives for $5 each
Some custom built computer (Intel Celeron 566Mhz, 128Mb RAM, 15.3Gb HD) for free
That concludes the craigslist finds.
Old 02-03-2012, 02:41 PM   #439
ratdude747
Black Sheep
ratdude747's Avatar
My Country: USA
found a brand new (still in retail packaging) targus chillmat for $8 at a thrift store...
Old 02-03-2012, 03:16 PM   #440
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
^ I didn't know Targus was available over there.
Then again.. the only Targus thing I've got is a headphone. A pretty darn good sounding one too, especially for free
It's a Targus AEH01 (or AEH-01)
http://www.targus.com/us/productdetail.aspx?sku=AEH01US
(I'm not using the "Talk-Through" blob thingie..)
The total lack of any kind of specifications on that thing anywhere on the web still confuses me..
Scenic is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
